Help with oil leak after injector install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 95 (permalink) Old 11-12-2007, 04:39 AM Thread Starter
Proud PSN Sponsor
Deputydog's Avatar
I just installed new injectors. Once I got everything back together, and tried to start it backfired. I let it sit for a minute, then tried starting again. It cranked and I saw white smoke coming from the engine compartment which went away within a few minutes. It took about 5 times of cranking it over but it finally started up. Now I have a huge oil leak somewhere near the rear of the engine and can't seem to find it. Almost looks like its coming out of the exhaust downpipe where it joins the rest of the exhaust. I let it run for several minutes before I noticed the leak and it ran awesome..
Any ideas?
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #2 of 95 (permalink) Old 11-12-2007, 04:41 AM
I make no power
Diezel Dawg's Avatar
Re: Help with oil leak after injector install
hmmmmm, weird
99.5 PSD 4x4, GTP38R BB TURBO, DP-Tuner, AFE Stage 2, 6.0L IC, MBRP 4" Turbo Back w/6" tip,
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Stage 2/3 Injectors or B-codes, Big Oil, BTS or JW tranny
Diezel Dawg is offline
post #3 of 95 (permalink) Old 11-12-2007, 04:42 AM
I make no power
did u make sure everything was tight??? torqued properly????
post #4 of 95 (permalink) Old 11-12-2007, 04:54 AM Thread Starter
Proud PSN Sponsor
Deputydog's Avatar
Yes .. I just tried to start it again and get all kinds of white smoke out the tailpipe.
820 HP on 05/19/12
post #5 of 95 (permalink) Old 11-12-2007, 04:55 AM
I make no power
hmmmm, u might have to take it out and drive it
post #6 of 95 (permalink) Old 11-12-2007, 04:56 AM
How long has it idled? You will get some oil out the exhaust for a few minutes/miles. And you will get some white smoke as well.
TerminatorEngineering is offline
post #7 of 95 (permalink) Old 11-12-2007, 04:57 AM
Banned
Send a message via Yahoo to blk99
NO dont drive it!! or you might end up like Joe! on the side of the road with a blown block.
blk99 is offline
post #8 of 95 (permalink) Old 11-12-2007, 04:59 AM
I make no power
i thought i have heard of white smoke and a little bit of oil after an install like that.
post #9 of 95 (permalink) Old 11-12-2007, 05:01 AM
Yup! My 95 was running oil out of the up-pipes. Sure sign of how bad my up-pipes were leaking!
post #10 of 95 (permalink) Old 11-12-2007, 05:01 AM
69W900A
69W900A's Avatar
You will have some residual oil and fuel that leaked into the cyl when you pulled the injectors. Are you actually seeing an oil leak? If it's coming out of the downpipe I'd check your oil level, you may have cut an inj o-ring.
TAG II, Exhaust Air Guide, K&N FIPK, Hood insulation delete, foil delete, SX and A1000 pumps, door dinger delete, COMPOUND trans coolers and a Banks Stinger+++ with the Banks TransCommand and Chrome curb Feelers.
248.9HP 4ft/lbs @ 3,400 RPM (don't forget to divide by 1,002 and carry the 5).
Nothing worse than a good idea that doesn't work.
69W900A is offline
