Setting TN wastegate actuator? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-11-2007, 04:09 AM Thread Starter
Mr. Bob's Avatar
Hey guys,
Had a quick question...
I have a TN non BB turbo to install on my truck, I hope next week....
I was thinking of adding my Banks BH actuator to it but decided no to...
I know that the banks says to set their actuator till you can slide it over the rod and pre-load 4 more turns...
I pulled the one off my TN and could easily slide it on and off...
Should I put some pre load on it??? should I leave it the way it was.... Bottoming out the rod gives me 4.5 turns....
Thanks for the help guys!!!!!
Bob
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #2 of 7 (permalink) Old 11-11-2007, 04:14 AM
<----Colin Banks
mattymx's Avatar
Re: Setting TN wastegate actuator?
I turned mine in 10 turns from stock on my BB...
mattymx is offline
post #3 of 7 (permalink) Old 11-11-2007, 04:22 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
I didn't touch my wastegate actuator, Kevin from BWD said it's set up just right from the factory, it looks just like a stock one but it's MUCH better. When i had the EBP gauge in my truck before BO i could run 27-28psi boost and have around 45 psi of backpressure.
Stock
PowerstrokeJunkie is offline
post #4 of 7 (permalink) Old 11-11-2007, 04:26 AM
I would give it a couple turns to tighten it down if it were me. Much easier to do on the bench than on the truck.
BigSlick is offline
post #5 of 7 (permalink) Old 11-11-2007, 04:30 AM Thread Starter
Mr. Bob's Avatar
Thats what I was thinking... its real easy now...
I can go a max of 4 turns... should I just put do all 4????
Mr. Bob is offline
post #6 of 7 (permalink) Old 11-11-2007, 04:34 AM
Yeah I would.. I cranked my Garrett all the way down and no problems at all.
BigSlick is offline
post #7 of 7 (permalink) Old 11-11-2007, 05:05 PM
I ran my ATS BB with the wastegate disconnected, just a rod to hold it shut.
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
outlaw5.0 is offline
