Low boost... So I think - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 04-11-2009, 02:13 PM Thread Starter
The Fireman
big_stroker's Avatar
I'm seeing what i would call very low boost out of my truck and it seems to be getting worse. At WOT in the all out setting on Matts chip when i 1st got the truck back i could hit 30psi pritty easy. then it dropped to about 26 now its hard to it over 20 in any setting.
I had checked everything I can think off... no soot on the up pipes or anything. and now boost leaks that i can find. All the boots where cleaned very well and everything when Nate put it back together.
Is this just the stocker dieing a slow and painful death?
big_stroker is offline
post #2 of 17 (permalink) Old 04-11-2009, 02:56 PM
Genius, when I drink
ditch_dawg's Avatar
Re: Low boost... So I think
Pop the intake off and check the compressor wheel and check end play.
If the compressor wheel is OK, drop the down pipe and check the exhaust side. Are all the bolts still holding the exhaust housing on?
On edit you might want to check the line for your boost gauge as well, especially if the truck does not feel like it has lost any power.
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #3 of 17 (permalink) Old 04-11-2009, 04:11 PM
matthewd11's Avatar
If there is no soot on the up pipes, the clamp at the bottom of the turbo is on good, and you've pressure tested the cold side, i'd suspect the turbo. As said, check it for play. Another thing to check is your intake plenums. Are you still running stock ones? I know you said you checked for boost leaks, but those can be a little deceiving. They crush inside the boot.
matthewd11 is offline
post #4 of 17 (permalink) Old 04-11-2009, 04:18 PM
Snake Oil Salesman
mattr66's Avatar
I broke the welds on my intercooler...... I had fun finding that leak....
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #5 of 17 (permalink) Old 04-11-2009, 04:20 PM
matthewd11's Avatar
was it a stock 7.3 I/C?
post #6 of 17 (permalink) Old 04-11-2009, 04:22 PM
Busy Busy
Marty's Avatar
Pull the intercooler and pressurize it.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #7 of 17 (permalink) Old 04-11-2009, 04:27 PM
Snake Oil Salesman
mattr66's Avatar
No it's a 12 inch crack on my spearco.... it is in for warranty right now.... it was sneaky because it was so wide you couldn't feel it but when i pressured up my intake system it would empty the compressor. It must have been cracked since last year because I started with 42lbs and it progressively got lower the more I ran it this year.... Maybe now I will see 50 psi...
Matt Robinson
mattr66 is offline
post #8 of 17 (permalink) Old 04-11-2009, 04:35 PM
Busy Busy
Marty's Avatar
oh i thiink i saw that picture lol.
Elkton, Maryland
Marty is offline
post #9 of 17 (permalink) Old 04-12-2009, 01:07 AM
Catfish Mafia
li'l tugger's Avatar
Send a message via Yahoo to li'l tugger
do you still have your wastegate plugged in? pull the vaccum line going to it and see if your numbers come up. my early 99 did similar to what you are saying.. and it was just the wastegate. if i understand it correctly, a spring holds it shut and that spring gets weak over time and cant hold the pressure.
li'l tugger is offline
post #10 of 17 (permalink) Old 04-12-2009, 04:27 AM
All done now
Arisley's Avatar
If checking that way, wire that puppy closed.
Arisley is offline
