headstud sealant ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-11-2009, 03:47 AM Thread Starter
wynndaddy's Avatar
headstud sealant ?
Does anyone use any type of sealant on the threads of their headstuds ? I've seen ARP has some and I read somewhere of using some loctite but did'nt know if it was needed on the 7.3 . Do they pass through any jackets? I dont want water chasing the threads , but most directions just say to use high psi lube .
1997 cc swb 4x4
wynndaddy is offline
post #2 of 11 (permalink) Old 04-11-2009, 03:55 AM
fueled by Colecovision
golfer's Avatar
Garage
Re: headstud sealant ?
no sealant is needed, as no headbolt holes pass openly into coolant jackets.
The "sealant" you referred to is actually a specialized lubricant (moly grease) that allows you to reach a very consistent and accurate torque value when installing the studs.
When we build an engine for a customer up north (where they salt the roads heavily) we will coat the exposed studs (those outside of valve covers) with either paint (to match the engine color) or a clear paint to prevent rust from attacking the studs from the outside.
take care~
Dave
golfer is offline
post #3 of 11 (permalink) Old 04-11-2009, 03:56 AM
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
I pretty sure you don't need to seal the studs with anything.
lildevil02 is offline
post #4 of 11 (permalink) Old 04-11-2009, 04:14 AM Thread Starter
wynndaddy's Avatar
Hey thanks for the quick responses . I thought that was the case but had been told diffrent and just wanted to be sure before I put them in .
1997 cc swb 4x4
post #5 of 11 (permalink) Old 04-11-2009, 04:36 AM
OverFuelingForYourPlesure
pontiacross's Avatar
I have seen some engines that the head bolts screwed right into the coolant passages I think maybe chevy did that on a couple
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #6 of 11 (permalink) Old 04-11-2009, 04:50 AM
Layson's Avatar
Yep... what has been said already... molly lube!!
Layson is offline
post #7 of 11 (permalink) Old 04-11-2009, 05:21 AM
Plays with Motors
Machinist's Avatar
It's very common, usually only the top row of bolt holes on a stock block are blind. Permatex #2A non hardening sealer is what I use.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #8 of 11 (permalink) Old 04-11-2009, 12:21 PM
Banned
It's a good idea to seal the ones outside the VC's so that they do not rust. After RE-purchasing enough studs to replace all the ones outside the VC's already, I can say with confidence that steps should be taken.
Charles is offline
post #9 of 11 (permalink) Old 04-11-2009, 12:50 PM
Soon to be a 6.4
lildevil02's Avatar
With molly lube or reg paint?
post #10 of 11 (permalink) Old 04-11-2009, 11:32 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
I would imagine a high temp paint.
SMOK'N BLUE STROKER is offline
