Marvel Mystery Oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 75 (permalink) Old 04-11-2009, 01:59 AM Thread Starter
Exclamation Marvel Mystery Oil
Anybody use this stuff? Best additive I ever used, in oil and fuel. Truck runs 100% better now, than when I bought it.
2000 F-350
jff987 is offline
post #2 of 75 (permalink) Old 04-11-2009, 02:00 AM
matthewd11's Avatar
Re: Marvel Mystery Oil
throw that stuff in the trash and run some ashless 2 stroke oil with the fuel. Only put oil the crankcase of these trucks.
matthewd11 is offline
post #3 of 75 (permalink) Old 04-11-2009, 02:14 AM Thread Starter
If I can get at wallyworld and if its = or less than $13 a gallon. I'll give it a shot.
2000 F-350
jff987 is offline
post #4 of 75 (permalink) Old 04-11-2009, 02:18 AM
matthewd11's Avatar
its about 11/gal and its available at walmart.
post #5 of 75 (permalink) Old 04-11-2009, 02:42 AM Thread Starter
13 qrt of shell rotella t and 2 qrt of MMO for crankcase. 4-8 fl/oz per 10gl diesel.
2000 F-350
jff987 is offline
post #6 of 75 (permalink) Old 04-11-2009, 02:45 AM
FNG
Dave's Avatar
Holy hell you are running MMO in your crankcase
Drain that #### and now. If you dont you may as well put some money aside for new injectors
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #7 of 75 (permalink) Old 04-11-2009, 03:15 AM Thread Starter
Yes, believe it or not, truck is running excellent.
2000 F-350
jff987 is offline
post #8 of 75 (permalink) Old 04-11-2009, 03:19 AM
jaybuller's Avatar
id say it will eat away at your injector barrels orings, ect.. because if im not mistaken its a solvent but i could be wrong. It might be running good now but might do long term damage
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #9 of 75 (permalink) Old 04-11-2009, 03:34 AM Thread Starter
Quess it would depend on type of material used for the O-rings.
2000 F-350
jff987 is offline
post #10 of 75 (permalink) Old 04-11-2009, 03:57 AM
FNG
Dave's Avatar
This guy is correct. It will do exactly that
Dave G
Dave is offline
