Over boost problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-08-2009, 04:10 AM Thread Starter
Big J power stroke's Avatar
Over boost problems
Have a Diesel Site boost relief valve & only works half the time& go's de- fuel check light on. Only trying to run about 30 psi boost. Any ideas? its on a 2000 7.3
Big J power stroke is offline
post #2 of 12 (permalink) Old 04-08-2009, 04:48 AM
Layson's Avatar
Re: Over boost problems
Is it the adjustable regulator??
Layson is offline
post #3 of 12 (permalink) Old 04-08-2009, 04:59 AM Thread Starter
No just a relief pop off
post #4 of 12 (permalink) Old 04-08-2009, 05:07 AM
Laces Out
bigrpowr's Avatar
it must be on backwards.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #5 of 12 (permalink) Old 04-08-2009, 05:09 AM Thread Starter
NO.sometimes it works but most not
post #6 of 12 (permalink) Old 04-08-2009, 05:20 AM
Snake Oil Salesman
mattr66's Avatar
what tuner are you running? Are you sure it is an overboost code and not an ICP code?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #7 of 12 (permalink) Old 04-08-2009, 12:51 PM
JHill's Avatar
try some wd-40 on it every oil change, I see over 30# boost without issue
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #8 of 12 (permalink) Old 04-08-2009, 12:55 PM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #9 of 12 (permalink) Old 04-08-2009, 01:01 PM
Snake Oil Salesman
mattr66's Avatar
some of the popoffs also don't like to be rubbing other stuff under the hood if it interferes with the free movement of the popoff valve.
Matt Robinson
mattr66 is offline
post #10 of 12 (permalink) Old 04-08-2009, 02:06 PM
Village Idiot
southmike's Avatar
wd- can attract dust
you could try a dry lube .
southmike is offline
