Big G Module - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-05-2009, 05:31 AM Thread Starter
01stroke's Avatar
Big G Module
Hey guys. You all are getting me into these mods on my mostly stock PS.
I was givin a Big G module to put on py 01. It is the fuel miser one. 50 hp and 150 lbs tourqe. I read some threads on here about stock head bolts and to much psi. Does this seem like a mild enough mod or should I worry about damage with 250k miles? My truck runs great and only has a open air intake for after market mods.
Thanks....Dan
2001 F250 Ext Cab LB 7.3 Super Duty 4X4 auto,Jody's Tunes, Single Shots, open air intake, AIH delete, AutoMeter Ultra-lite2 Gauges, triple pod, Mile Marker hubs,259,999 mi. then odometer broke Oct. 09. MBRP 4" turbo back. Banks power elbow. Non ebpv ped. plus wicked wheel.
Don't spread my wealth...spread my work ethic
01stroke is offline
post #2 of 12 (permalink) Old 04-05-2009, 05:43 AM
<-- it's like that
Re: Big G Module
Don't even bother with it. It's just a sensor fooler for the ICP and the oil temp sensor.
Get a real chip or programmer that will do much much more.
As for power increases, your heads will be fine with whatever chip you do throw in there.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 12 (permalink) Old 04-05-2009, 12:24 PM Thread Starter
01stroke's Avatar
Re: Big G Module
Very good. Thank you. I guess I'll give it back to him...if he don't want it maybe ebay will help.
I can tell on here what the better chips are...yes I'll buy from a sponsor
01stroke is offline
post #4 of 12 (permalink) Old 04-05-2009, 02:37 PM
Butt-Head
PHPDiesel's Avatar
Re: Big G Module
If it's just been given to you, run it. If you're not in a financial situation to buy anything right now, then go ahead and install it. It's not going to hurt anything. If anything, it will give you a greater appreciation for actual tuning that comes with a programmer or chip.....vs. just fooling sensor inputs.
EDIT:
Those "signal corrupting devices" DO work ok. Ok as in, they make a noticeable difference.
Cody
PHPDiesel is offline
post #5 of 12 (permalink) Old 04-06-2009, 04:02 AM
Village Idiot
southmike's Avatar
Re: Big G Module
free is free
sometimes you get better milage and more power.
run that for a bit and save sopme pennies for your favorite chip
southmike is offline
post #6 of 12 (permalink) Old 04-06-2009, 04:51 AM Thread Starter
01stroke's Avatar
Re: Big G Module
Thanks guys. I will run it for now.
I checked into some mods and like the options of the Edge Attitude. I have heard their not all thier cracked up to be. I also liked the DP F5 16 position shift on the fly....and $200 ain't bad at all.
Would I be better off with the DP or is the options and info screen with the Edge better?
01stroke is offline
post #7 of 12 (permalink) Old 04-06-2009, 04:55 AM Thread Starter
01stroke's Avatar
Re: Big G Module
What the hell happened to my signature????
01stroke is offline
post #8 of 12 (permalink) Old 04-06-2009, 05:05 AM
Mr. Bob's Avatar
Re: Big G Module
Better off with a DP tuner!
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #9 of 12 (permalink) Old 04-06-2009, 01:56 PM
The Fireman
big_stroker's Avatar
Re: Big G Module
Your Signature will only work in the 1st post that you make on that page.
Oh and I would go with a custom chip from Matt R. names mattr66 on here.
big_stroker is offline
post #10 of 12 (permalink) Old 04-06-2009, 07:15 PM
Village Idiot
southmike's Avatar
Re: Big G Module
dp chip will be way stronger then an edge.
but see if someone like jody or bill at php can tune them.
best of both worlds.
