I've got a bad exhaust backpressure sensor, but does it even matter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 11-07-2007, 03:52 PM Thread Starter
sandnut's Avatar
Using AE software, I can pull a couple codes related to backpressure being too high, and when I monitor that sensor, it reads 14.5 psi with KOEO. I don't see how there could be that much pressure with the engine turned off, so the sensor must be bad. I've got a non-EBV turbo & pedestal, and some people say it makes no difference, others say the computer will see the difference between the turbine & compressor & cut back on fuel, timing, etc to keep from damaging the turbo. Does anyone know if the computer does this or not?
If I need to fix this, should I get a new sensor, or would Dfuser's sensor eliminator fix the problem?
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff...
sandnut is offline
post #2 of 31 (permalink) Old 11-07-2007, 04:00 PM
Banning Smut
PTSUPERD's Avatar
Re: I've got a bad exhaust backpressure sensor, but does it even matter?
I bought the SP version of this and have never looked back. Cheaper than a new sensor. lol
PTSUPERD is offline
post #3 of 31 (permalink) Old 11-07-2007, 04:03 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
sandnut 14.5 is normal atmospheric pressure. You must be @ about 1500-2000K in elevation. Mine read 15.4 and I'm 2 about 300 feet above sea level. Check your EBP sensor. It sits in front of your HPOP resovour. Pull it out and see if it's cloges with carbon. Also start your truck with it out and make sure you can feel/see exhaust flowing out of it. It could just be a clogged tube or a bad sensor.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #4 of 31 (permalink) Old 11-07-2007, 04:03 PM
i run a map eliminator and ebps eliminator, truck runs 100%
Power Stroke is offline
post #5 of 31 (permalink) Old 11-07-2007, 04:09 PM
Haul_n_horses2's Avatar
I seem to recall a statement attributed to Jody that the programs ran better (more reliably?) with an intact sensor?
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #6 of 31 (permalink) Old 11-07-2007, 04:14 PM
A Ghost these days.
mad_matt's Avatar
Hauln you are correct. It helps with Fuel mapping Jody mentioned that while we was live tuning Boggers Truck.
Got Boost?
Dynojet
13.152 @ 104.7 mph
mad_matt is offline
post #7 of 31 (permalink) Old 11-07-2007, 04:15 PM
Banning Smut
PTSUPERD's Avatar
Really? If this is a fact I could rethink... Truck is fueling fine great though.
PTSUPERD is offline
post #8 of 31 (permalink) Old 11-07-2007, 04:23 PM
A Ghost these days.
mad_matt's Avatar
PTS I'm putting mine back in for tuning @ least. But as for Jody's comment Bogger or Joe Diesel and VAPStroke were standing right there when he said that.
Got Boost?
Dynojet
13.152 @ 104.7 mph
mad_matt is offline
post #9 of 31 (permalink) Old 11-07-2007, 04:24 PM
Banning Smut
PTSUPERD's Avatar
Thanks Matt
PTSUPERD is offline
post #10 of 31 (permalink) Old 11-07-2007, 04:26 PM
fbilly420's Avatar
you can pick up a new sensor off ebay for 25.00.
That is what I did and cleaned the tube and I noticed a slight increase in fuel mileage as well.
Billy
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
