CCV Mod? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-04-2009, 07:14 AM Thread Starter
Question CCV Mod?
Being doing some research and looking around at past posts.. Wanting to do the ccv mod and wanted some input on how to and the best way. Should i do a diy mod or buy the ccv mod from stealth auto (NC Hornet). And ive also got an oil leak on my truck, ive checked the turbo, hpop and i cant seem to find where its coming from? It is coming down the back of the block on both sides and running down the middle of the oil pan and around the front of the transmission? Anybody got any ideas what it mite be leaking from?
2001 F-250 7.3L PSD 4x4, S&B CAI,Zoodad Mod,Foil Delete,Van Turbo,WW,4" DP w 5" Exhaust,CCV,HPOX,DP Tuner(high idle,lope,60hp,80hp,120hp,140hp)ITP Overboost Anhilator,Autometer PYRO & Boost, 2" Rear Lift w 2.5" Skyjacker Leveling Kit, Procomp ES9000 Shocks..
lpoutfitters81 is offline
post #2 of 9 (permalink) Old 04-04-2009, 08:27 AM
Grumpy Old Man
Re: CCV Mod?
Re the CCV mod, it's a piece of cake. Remove the "Dog House" (CCV Can) and reposition it facing the firewall. Run a long length of 5/8" (I Think) hose up and over the power brake unit then down along the frame behind the cab so you don't get fumes in the cab.
Be careful that you don't get any sags in the line as oily moisture will collect and eventually cause back pressure. The reason that you run the line over the top of the power brake unit is to allow oily moisture to run back into the engine.
The Oil leak:
First, clean the valley squeaky clean using..BrakeKleen, Simple Green, etc and a whole bunch of paper towels to mop it dry. You will probably find all kinds of stuff in there from missing wrenches, rats nests, etc. Really, really clean and dry.
Using a "Bright" flashlight and a good mirror, start the engine and start looking. Check the "Weep" hole at the back of the lift pump, check very carefully around and under the fuel filter, all hose fittings and especially the sensors on the drivers' side of the fuel filter. Also check the bottom of the filter for holes. Standing water and crud has been known to eat holes in the bottom of the canister.
Be meticulous and patient and you will find the leak,
Good luck,
Rog
kawa is offline
post #3 of 9 (permalink) Old 04-04-2009, 11:39 AM
4cstr's Avatar
Re: CCV Mod?
With respect to the CCV mod...I double the point about being careful about sags in the line...especially if you are in a cold climate..ie...it gets below freezing. A frozen shut line due to ice creates a big...messy problem.
early 99, old, slow but paid for.
4cstr is offline
post #4 of 9 (permalink) Old 04-04-2009, 11:53 AM
Milk Truck
abianca99's Avatar
Re: CCV Mod?
You can also check where your dipstick goes into the oil pan. I have had a small leak there for years.
99.5 F250 cclb 4x4...modded, but looks stock
abianca99 is offline
post #5 of 9 (permalink) Old 04-04-2009, 11:59 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: CCV Mod?
Dont forget to plug the hole-up thats in the intake from where the hose used to be plugged into or replace it with 4'' tubing. ITP diesel has a very nice ccv mod.kit.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #6 of 9 (permalink) Old 04-04-2009, 12:38 PM
SyN
Lubrication Addict!!
Re: CCV Mod?
Agrees with Dixieland-->ITP has a nice mod kit. This is the one I installed.
Just remember: If your 7.3L has alot of miles on it, ya {might}& might not have the same problem I have. A steady stream of smoke, and oil droppings every time ya park the truck for an extended time. I wonder what the inside of my intercooler looks like?
With the kit from Stealth->(NC Hornet) You will not have the smoke or leaking oil-->kinda nice. But ya pay for that extra nice.
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
SyN is offline
post #7 of 9 (permalink) Old 04-04-2009, 01:18 PM
Re: CCV Mod?
The Oil leak:
Good luck,
Rog
good idea's except the weep hole thing. the lift pump is on the frame rail. I would guess it's the fuel filter housing leaking. I have seen this on several SD, it is enough of a problem Alliant power made a kit with the O-rings to fix the problem. Also I would try to just run the hose down for a few days to see if you are getting enough residue that you need to run it over the brake booster. I had 90,000 on my 03 & I have 227,000 on my early 99 and neither one leaves any residue.
Jay
1999.5 F250 CCSB 4x4 stock for now
straitcountry is offline
post #8 of 9 (permalink) Old 04-04-2009, 06:00 PM Thread Starter
Re: CCV Mod?
Would it be easier just to replace the 4" tubing on the intake?? And im frustrated with this oil leak ive searched and searched im gonna clean out the valley and give everything a good once over again this afternoon and see what i come up with... Hoping its something simple i can fix..
post #9 of 9 (permalink) Old 04-04-2009, 11:22 PM
Thomas7.3psd's Avatar
Re: CCV Mod?
i had an oil leak that was coming out of the boots that hold the intake plentum to the manifold on the heads, you may check that out. mine was also draining off the back of the motor down the bell housing.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
