Drive Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-03-2009, 04:06 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Drive Pressure
Can I check drive pressure on just one bank or do I need to combine sensing lines to both banks to be accurate?
At what point (ratio) does drive pressure need to be wastegated off? What is acceptable and what is excessive?
What is more important, getting drive pressure down to a 1-1 ratio or running a compressor within its map, or is this the same thing?
907DAVE is offline
post #2 of 7 (permalink) Old 04-03-2009, 05:31 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: Drive Pressure
running a compressor within its map will (in general) keep the drive pressure down to reasonable levels. Most people get high drive pressure when they start getting into the less efficient areas of the compressor. This means more energy is required to compress the volume of air, most commonly seen as high drive pressure.
Go ARMY!
cowboy_dan is offline
post #3 of 7 (permalink) Old 04-03-2009, 11:45 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: Drive Pressure
907DAVE is offline
post #4 of 7 (permalink) Old 04-04-2009, 01:53 AM
moore20017.3's Avatar
Re: Drive Pressure
If you notice the stock turbo will make 20-23psi failry efficiently, then it will make 25psi boost until it comes apart.
At 20 IIRC the backpressure was close to a 1:1 but when you max it out on the exhaust side the back pressure climbs and the boost goes nowhere. At this point it is requiring more horsepower to drive the turbine than it is giving back in map pressure.
Think of the engine as an air compressor, does it take the same size motor to make 20psi as it does to make 60psi? No, the more the backpressure the more the parasitic loss. This is why I never understood unhooking the wastegate.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #5 of 7 (permalink) Old 04-04-2009, 02:20 AM
hotstik's Avatar
Re: Drive Pressure
You have two 1/8 npt ports on the top of your TN pedestal. Take your drive pressure readings for the small turbo from one of those.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #6 of 7 (permalink) Old 04-04-2009, 02:04 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
Re: Drive Pressure
thats the best place to check it.
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #7 of 7 (permalink) Old 04-04-2009, 03:12 PM
Re: Drive Pressure
Well, I didn't know he was so well equipped.
Those TN setups are top notch. I would come out and tee them together so that you are reading both banks if it is a divided inlet setup.
How do you guys running this integrating a wastegate? Is it part of the turine or something in the up pipes.
