doh! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-02-2009, 03:01 AM Thread Starter
<- My lucky set of PMR's
96centurion's Avatar
doh!
Well I had created what I thought should be a pretty reliable dummy proof setup for my truck, but I missed being on the edge, so I bought a set of BD Injectors. I am going to leave them stock besides changing nozzles, but I'm thinking the truck will run a little different now. I am going to have them tuned down some, but there should still be a lot more fuel there than with the stage 2's.
I think there are quite a few people running these injectors nowdays... any advice on keeping a stock motor besides headstuds together? I didn't do much to the new motor because the plan was to stay with the stage 2's as a permanent setup that didn't last long. setup is in sig.
Carl Evers
1996 Centurion conversion- Casserly 250cc BD's, Terminator HPOS, ITP Reg. return, ATS A5000 w/ early 99 intercooler, ATS Propane system and stage IV transmission with 5star and billet flexplate, DP Tuned
96centurion is offline
post #2 of 6 (permalink) Old 04-02-2009, 02:30 PM
The Fireman
big_stroker's Avatar
Re: doh!
Keeping a stock motor together is all about tuning. But I thought Hybrids where better and safer than B codes? But I could be wrong.
big_stroker is offline
post #3 of 6 (permalink) Old 04-02-2009, 06:12 PM
Fierro Racing
BeastPowerX10's Avatar
Re: doh!
i would talk to Joey- Terminator Engineering . he could give you some pointers. with the proper tuning you can make those b's run like those stageII's did. talk with Jdub he is running B's as well.
2008 rclb Tow Rig Edition
71 Gated Deleted
Hallers Diesel Performance
Who Needs Swagger When You Got Stagger
BeastPowerX10 is offline
post #4 of 6 (permalink) Old 04-02-2009, 09:36 PM Thread Starter
Re: doh!
Whoops. I forgot to write down that I was mostly curious about the top end- what most people think about the necessity of valve springs and pushrods at this point. I talked to Jody about tuning before I bought the injectors and he already as plans for driveability and making the bottom end live, so I am not worried about that. Would those who have already run these injectors reccomend I take the time and spend the money for valve springs and pushrods at this point?
Carl Evers
post #5 of 6 (permalink) Old 04-02-2009, 09:38 PM Thread Starter
Re: doh!
That very well could be true. I got my B codes for a pretty good price, that is the main reason I bought them. I also liked the idea of a mostly unmodified injector because I have had terrible luck with injectors so far.
Carl Evers
post #6 of 6 (permalink) Old 04-03-2009, 11:55 AM
The Fireman
Re: doh!
Well good luck with them B codes
