Fuel Pump Upgrade? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-31-2009, 03:55 AM Thread Starter
Fuel Pump Upgrade?
Hi there, this is my first post here so I'll try not to sound like a complete noob. I was recently told that my fuel pump might be on its way out and was wondering if I should replace it with upgraded pump/system or are the stock ones capable enough for the regular mods?
The truck is an early '99 with Afe stage 2 intake, upgraded up pipes, IC, 4" exhaust, and an edge attitude w/ juice. I'm still not satisfied with the power so there will be more modding to come. Any opions or suggestions on pumps or systems I should be looking at? thanks
orly is offline
post #2 of 16 (permalink) Old 03-31-2009, 04:00 AM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Re: Fuel Pump Upgrade?
If you want a new fuel pump I would reccomend a fuel lab pump.
SMOK'N BLUE STROKER is offline
post #3 of 16 (permalink) Old 03-31-2009, 05:18 AM
Drink til she's cute
Thuglike's Avatar
Welcome to the nation. In regards to your fuel pump replacement go to the sponsors section on top of the page and scroll down to ITP Diesel. Dennis will set you up right.
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #4 of 16 (permalink) Old 03-31-2009, 06:24 PM
Send a message via AIM to JohnT
Depend on how much money you have. To run a fuel lab, you will need more than just the pump. The intake side of the pump I know for sure will need bigger lines. Then you will need to run a relay and larger wires to the pump. $500+
Stock Fuel pump <$200
What problems is your truck having that you are being told that your pump is going bad?
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #5 of 16 (permalink) Old 04-01-2009, 05:18 AM Thread Starter
I recently had it in at a mechanic and he said one of the codes that came up was a indication of a weak pump. He just gave me a heads up that I might need to replace it soon. I am only able to build 15 pounds of boost according to my edge monitor, could this have something to do with fuel or lack there of?
orly is offline
post #6 of 16 (permalink) Old 04-01-2009, 08:15 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
the fuel lab pump is 4oo bucks..i will be going with the $118 walbro pump..better then stock yet cheaper then stock..low fuel could be the cause..i would check for boost leaks or up pipe leaks first..
http://cgi.ebay.com/ebaymotors/WALBR...mZ360141552061
Ron's power stroke is offline
post #7 of 16 (permalink) Old 04-01-2009, 12:49 PM
Banned
One thing to keep in mind is that you can run the Fuelab pump at whatever speed you want. If you turn it down, you can run smaller lines.
Charles is offline
post #8 of 16 (permalink) Old 04-01-2009, 12:55 PM
Waitin' on 500
Choupique108's Avatar
i had a FASS on my cummins and it was amazing. if i had to do it again, id go the same route
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #9 of 16 (permalink) Old 04-01-2009, 12:56 PM
Banned
What fuel pressure did that Fass run at on your Cummins? The difference between that, and the pressure a 7.3 system runs at is why you would likely not have the same luck.
Is the OP even looking for a performance pump of any sort? If not, a walbro is the quickest, and easiest fix by far. That or a stock replacement, although I have no idea what code can come up to indicate a failing fuel pump myself.
Charles is offline
post #10 of 16 (permalink) Old 04-02-2009, 08:16 PM
Waitin' on 500
i kept a constant 15psi with smarty level 9
1997
Single Cab Dually
