Turbo replace, Stock or Aftermarket???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-29-2009, 02:56 PM Thread Starter
'01, 7.3, 132,000 miles, Superschip programer (can add 60, 80 or 110 Hp), all stock, enclosed trailer max weight 7000 lbs.
No problems with turbo now. Just want to do my homework before there is a problem. Replace with a Ford turbo or an aftermarket one. Does a turbo help with better MPG? Haveing the truck reliable is more important than anything.
Thank you, Skrugs
2001, Crew Cab, 4x4, Short Box
Skrugs is offline
post #2 of 6 (permalink) Old 03-29-2009, 02:57 PM
Super Hauler!
Super_Hauler's Avatar
Re: Turbo replace, Stock or Aftermarket????
GT38R!
Super_Hauler is offline
post #3 of 6 (permalink) Old 03-29-2009, 03:01 PM
Snake Oil Salesman
mattr66's Avatar
Originally Posted by powerstrokinc View Post
GT38R!
I second that! That charger will support you now and later when you want to get some more injector.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #4 of 6 (permalink) Old 03-29-2009, 03:26 PM Thread Starter
Where to buy?
Thanks for the short and direct answers.
Skrugs is offline
post #5 of 6 (permalink) Old 03-29-2009, 03:30 PM
Snake Oil Salesman
mattr66's Avatar
PM Sent.
Matt Robinson
mattr66 is offline
post #6 of 6 (permalink) Old 03-29-2009, 04:51 PM
Village Idiot
southmike's Avatar
di sells them ...
and not trying to be a funny man
but ask matt66 about tunes .
there is a night and day difference between a chip and a programer.
biggest thing to check on your truck is
ball joints, front bearings if it is 4wd,
o-rings on the fuel filter ,
water pump (have a look at a coolant filter from dieselsite.com)
ditching the oem airbox with one that won't dust an engine
and if it has a mechanical diode tranny.
southmike is offline
