Formula for finding injector CC's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-28-2009, 01:16 AM Thread Starter
Built By Me
444smoker's Avatar
Alright its been awhile so im a little rusty and having a brain cramp. Isnt the formula for finding the volume of the fuel in an injector (plunger surface area x intensifier piston stroke) ??? I did this on a set of injectors i have and came up with some numbers that arent what i thought they were.
For example a stock BD530 injectors plunger surface area= .873in
and the intensifier piston stroke= .250in
.873x.250= .218cc's ???
Now am i missing a step or is this the number? I thought that the stock BD's were around 240-250ish???
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
444smoker is offline
post #2 of 13 (permalink) Old 03-28-2009, 02:15 AM
squeak12's Avatar
Re: Formula for finding injector CC's
I'm not sure if that is right, but you have to multiply the end by 1000 since they are classified by how much volume they expend in 1000 shots. Think you are using the right formula in bore X stroke, but I'm not savvy in the injector field.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #3 of 13 (permalink) Old 03-28-2009, 03:00 AM
Sponsor
First of all you shouldn't be using Inches... Its Millimeters...
Surface area of a 530 plunger is 39.59mm
If the travel is 6.35mm (.250 inches)
Then the "Maximum Estimated" cc flow rate would be 251.4cc's per 1000 injection cycles
UNLIMITED_DIESEL is offline
post #4 of 13 (permalink) Old 03-28-2009, 03:09 AM Thread Starter
Built By Me
444smoker's Avatar
Ahh! me doesnt think in mm to often thanks.
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
post #5 of 13 (permalink) Old 03-28-2009, 03:10 AM
Sponsor
does that help with your calculations???
post #6 of 13 (permalink) Old 03-28-2009, 03:16 AM Thread Starter
Built By Me
444smoker's Avatar
One more, what is the surface area of an A code plunger?
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
post #7 of 13 (permalink) Old 03-28-2009, 03:17 AM
Sponsor
28.27mm
post #8 of 13 (permalink) Old 03-28-2009, 03:28 AM Thread Starter
Built By Me
444smoker's Avatar
28.27mm
okay. Looks like im going to be going over this with my college math professor tomorrow,
My caliper came up with a diameter of .278 of the plunger (B codes)
multiply that by 3.14 for the area .873in converted to millimeters and the outcome is 22.174mm not 39.59
maybe this is getting anoying but i feel like im getting kicked in the nuts over this, Ha Ha.
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
post #9 of 13 (permalink) Old 03-28-2009, 03:36 AM
Sponsor
Forget inches. Use your calipers and find the millimeters...
530 Plunger is 7.1mm in diameter, divide that by 2 and come up with the radius. 3.55mm... Multiply 3.55mm x 3.55mm and come up with 12.6025mm... Multiply 12.6025mm x 3.14 and come up with 39.57mm. Close enough
Do the same for A code plunger... 6.0mm divided by 2 equals 3.0mm... 3.0mm x 3.0mm equals 9mm. 9mm x 3.14 equals 28.26... Again, close enough
post #10 of 13 (permalink) Old 03-28-2009, 03:43 AM Thread Starter
Built By Me
444smoker's Avatar
Alright the student now understands the teachers lesson, thanks man!
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
