SWAMPS GEN3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 100 (permalink) Old 11-04-2007, 08:59 PM Thread Starter
mattrac's Avatar
SWAMPS GEN3?
swamps gen3 pump any one have any input pro and cons?
mattrac is offline
post #2 of 100 (permalink) Old 11-04-2007, 09:01 PM
<<HowdoIgetridofthat
Imjosh's Avatar
Re: SWAMPS GEN3?
Charles?
02 F250 4x2 362rwhp/760rwtq
13.942 @ 98.44mph
Dp Tuner
Van Turbo w/ Wicked Wheel
Swamps 175/146
So this is how liberty dies. With thunderous applause.
Originally Posted by Big Bore View Post
John Wayne doesnt care where you watch his movies, and beer doesnt care where the refirgerator is.
Imjosh is offline
post #3 of 100 (permalink) Old 11-04-2007, 10:18 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: SWAMPS GEN3?
The big oil systems are split into 2 basic catagories; the twin OEM style, and the gear pump style.
The Terminator and the Stealth both use twin OEM PSD style pumps inline using a special shaft and adaptor plate. OBS trucks have to use a different fuel system as the fuel bowl is too tall with them.
BTS uses a mix of the two. Their pump is a OEM piston pump, but not from PSD motors. They use a gear and run their pump off the OEM HPOP gear. They use a SD oil reservoir and a SD fuel bowl. If you don't know what you're looking at, it really looks stock because the adaptor block is so small and covered up with other stuff.
The Gen3 uses a (I believe hydraulic) gear pump mounted on a IH T444E reservoir. It can use the stock OBS fuel system, but it requires some creative mounting of the fuel canister. The Gen3 system utilizes a gear drive similar to the BTS system. There was an issue with a Gen3 hose causing a fire, but that has since been replaced with solid steel lines.
Some people have expressed opinions that the inline systems put too much stress on the first shaft, creating a possible breakage point. I have not seen any reports of this.
Others have stated that the gear lash on the gear drive systems needs to have a method to adjust lash. The BTS system has this. I personally don't think it is necessary with the Gen3 system because the manufacturing tolerances on the T444E reservoir are made to keep the gear lash within spec.
Dual IPRs is a constantly debated topic, with some saying that they're not necessary with programming. Others say that they are necessary to run in stock mode. As I understand it, the stalling problem is normally noticable on manual trans trucks. BTS, Terminator, and Gen3 use a single IPR. Stealth normally comes with 1, and has instructions on how to add a 2nd.
There is/was a pump known as the Psychopump that replaced the OEM pump completely. It was a fairly large displacement gear pump, but it had warm start issues. These have apparently been resolved, but no more production has been announced.
Very good results have been seen from all the big oil systems. Cale Thompson (of BTS) runs their system on his twin turbo truck at about 700hp. It was also the choice (as if there was any other) for the white truck that Alan Black has. That system will be going on his wife's Expedition due to unforeseen circumstances. Elmo I believe runs the Terminator, along with almost everybody else on this site.
The inline OEM pumps are especially nice for most compound setups because that room is usually wasted (or not used well) otherwise. But, Cale's truck has compounds & their oil system. Someone else made a lookalike to a Gen3 system and had it running triples for a while.
All four are good systems. All four have had some growing/development pains. All four are making HPO for some strong running trucks. The choice is yours.
Go ARMY!
cowboy_dan is offline
post #4 of 100 (permalink) Old 11-04-2007, 10:37 PM Thread Starter
mattrac's Avatar
Re: SWAMPS GEN3?
thanks for input hope to have it on by next weekend
mattrac is offline
post #5 of 100 (permalink) Old 11-04-2007, 10:47 PM
Banned
Re: SWAMPS GEN3?
Well if you've already got the fuel bowl out of the picture it should go on in minutes.
Charles is offline
post #6 of 100 (permalink) Old 11-04-2007, 11:08 PM Thread Starter
mattrac's Avatar
Re: SWAMPS GEN3?
i mounted filter and water sep under truck and have alum block made up to connect fuel lines together from itp return reg system right now im running factory fuel filter i will tie it all together when i install it.i hope all goes well how long should it take?
mattrac is offline
post #7 of 100 (permalink) Old 11-04-2007, 11:24 PM
you want some of this?
smorris's Avatar
Re: SWAMPS GEN3?
Maybe thirty minutes? If the fuel system is out of the way the install will be a breeze. Also, the stalling problem is a non-issue. Just be sure to get the programming for the system. Mine had the stalling deal, and Jody fixed it right up.
2000 f-350 cc lb dually 4x4, BTS transmission
[email protected] 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #8 of 100 (permalink) Old 11-04-2007, 11:28 PM Thread Starter
mattrac's Avatar
Re: SWAMPS GEN3?
have swamps 6pos chip coming in the box with gen3
mattrac is offline
post #9 of 100 (permalink) Old 11-04-2007, 11:40 PM
smorris's Avatar
Re: SWAMPS GEN3?
Good deal!
smorris is offline
post #10 of 100 (permalink) Old 11-04-2007, 11:51 PM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
Re: SWAMPS GEN3?
mine came in yesterday and i installed my gen3 pump today! very easy....now all i have to do is install my fuel system.
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
