early 99 mods? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-25-2009, 01:20 AM Thread Starter
NorCal997.3's Avatar
early 99 mods?
New to the whole diesel performance thing. I have a DIY intake and superchips tuner but looking to see what other mods I can do to it. Thinking about getting a DP tuner, as I've heard alot of good things about it. What about turbo/injectors/hpop? It seems like the early 99 is limited to modifications. I don't race the truck or antything just looking for a few more horsepower.
Thanks
NorCal997.3 is offline
post #2 of 8 (permalink) Old 03-25-2009, 01:35 AM
Super Hauler!
Super_Hauler's Avatar
Re: early 99 mods?
First off, is it auto or manual? If auto get rid of the superchip it will eat your tranny. Next you can do the later 99 conversion of the intake manifolds and pedistal and get a GT38R or a stock 2000 turbo. Injectors i would do some hybrid 160 cc or DIY 160cc. HPOP you could do a twin 17* or just stick one 17* HPOP because yours has a 15*. Its really up to you and how deep your pockets are. If you did all that you would get around 380-400 hp with a DP or PHP tuner.
Exhaust and Intake is a must if not done already, get some gauges to monitor your temps.
Super_Hauler is offline
post #3 of 8 (permalink) Old 03-25-2009, 02:03 AM
Back to Civilian Life!!
MILFORD's Avatar
Re: early 99 mods?
Exhaust intake and gauges are the first 3 you need to do. Gauges are very important. I would get a chip with some good tunes and a VB from BTS if you have an auto. You are only as limited as your pockets let you be. Look here in the classified section there is always good stuff for sale.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #4 of 8 (permalink) Old 03-25-2009, 02:09 AM
JHill's Avatar
Re: early 99 mods?
If your staying stock or up to stage 2's,a D66 is a drop in and flows some air
http://www.beansdieselperformance.co...es/cat_65.html. not as durable as GTP38R but a nice piece for a DD.
you also need up pipes, Ypipe for the 99+ conversion
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 8 (permalink) Old 03-25-2009, 06:37 AM Thread Starter
Re: early 99 mods?
Already have exhaust, intake, tranny gauge, and boost and pyro ready to be installed.
How hard is to convert it to 99+? How much cost too?
post #6 of 8 (permalink) Old 03-26-2009, 12:10 AM
MILFORD's Avatar
Re: early 99 mods?
If you are planning on going with injectors up to a stge II go with the D66 dont convert it. If your going to go with anything bigger then stage IIs just go with a H2e Hypermax kit and be done worrying about the turbo.
MILFORD is offline
post #7 of 8 (permalink) Old 03-26-2009, 01:21 AM
Fro_911's Avatar
Re: early 99 mods?
The conversion to 99.5+ is not bad, you can get it done in one day if you have all the parts. A second pair of hands helps ALOT!
Early '99 F-350 CC 4x4
"Nobody hates you more than your own reflection" - Atmosphere
Fro_911 is offline
post #8 of 8 (permalink) Old 03-30-2009, 12:47 AM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Re: early 99 mods?
You can stay with you r early 99 setup and still run hybrids. Youll need a super d 66 to do so. Talk to Unlimited Diesel. Theyll help you out!
SMOK'N BLUE STROKER is offline
