Parts swap issues!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-15-2009, 02:59 PM Thread Starter
Parts swap issues!?
I am ready for the many slaps in the face so here goes...
Doing a swap in an early 99. Long block is out of my dad's 02. What is not gonna fit? Did some reading in the forums and found there were quite a few more differences than what I thought.
strokinsince'95 is offline
post #2 of 15 (permalink) Old 03-15-2009, 03:43 PM
suprdzlduty's Avatar
Re: Parts swap issues!?
your intake plenums, intake manifold, turbo pedistal, turbo, and uppipes are the majority of differences, unless you can snag that stuff from the 02. Nothing that isnt bolt on/off.
suprdzlduty is offline
post #3 of 15 (permalink) Old 03-15-2009, 03:48 PM Thread Starter
So it all bolts up in the same places, just different sizes(intake, turbo, etc.)?
post #4 of 15 (permalink) Old 03-15-2009, 04:13 PM
Send a message via AIM to Barnbuilder
Wiring harness.
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #5 of 15 (permalink) Old 03-15-2009, 04:40 PM
What else?
smokyred's Avatar
If you swap all the parts from your 99 onto the 02 motor that don't look the same you'll be golden. What the guys stated above are what needs swapped, not really a big deal if you've got the motor out.
Dave
smokyred is offline
post #6 of 15 (permalink) Old 03-15-2009, 05:08 PM
JHill's Avatar
unless I am missimng something why not by new uppipes and drop the sucker in. other than the harness wich I
In another post, didnt you mention new injectors and a chip?
PMR comes to mind. thought about headstuds while its out.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #7 of 15 (permalink) Old 03-15-2009, 05:17 PM
Layson's Avatar
Originally Posted by JHill View Post
PMR comes to mind.
Layson is offline
post #8 of 15 (permalink) Old 03-16-2009, 03:16 AM
Well Hung Member
stroked's Avatar
yeaaa, if its on the engine stand, forged rods are too easy to comeby to transplant a pmr'd engine in to anything...
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #9 of 15 (permalink) Old 03-16-2009, 05:26 AM
Village Idiot
southmike's Avatar
is your motor shot , mia etc..
if not switch the hpop, injectors, turbo and all its related stuff onto your block.
stick with the hard parts ..pcm's are different , gauge cluster is different..
e99 had no aih ,..foiled pipe ic will be diff as well.
and as mentioned pmrs will suck
southmike is offline
post #10 of 15 (permalink) Old 03-16-2009, 03:45 PM Thread Starter
Got new headstuds w/ master kit. I think I'll just go rob a 99.5 or < for the parts I need. (salvage or part out) Somebody said something about PCM's being different. So, it won't work or the connectors on the harness are diff? I'm confused. The e99 and 02 tunes from Ford are that much diff? I thought I had a sweet deal, but looks like I got some decisions to make.
