will it work? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-14-2009, 11:46 PM Thread Starter
chris 0.'s Avatar
will it work?
im looking at a used 8" lift off an early 99 f-350 4x4 dually. will it fit on my 2002 single rear wheel?
Thanks,
Chris 0.
chris 0. is offline
post #2 of 13 (permalink) Old 03-15-2009, 04:06 AM
Re: will it work?
I think the track bar mount is different. Anyone sure on that?
707.3 is offline
post #3 of 13 (permalink) Old 03-15-2009, 04:50 AM
Re: will it work?
Yes the track bar on the 02 has a larger bolt. If you get the track bar bracket off the 02 it will take care of the bracket side the problem is that bracket that is mounted to the Axel is welled on.
I had a custom adjustable track bar made for my truck to take care of this issue.
If you live in AZ come join us at Arizona Powerstroke Group... Click here
99.5 F-350 BTS Trans / Termys / Swamps 200/30 AA Injectors / Swamps IDM / GT38R BB Turbo / AFE Stage 2 / DP/ Evans Coolant, ART Rotors / Dynatrac Spin Free HD Front Hubs, 4 inch Stainless Exhaust, Auto Meter Cobalt Gauges.
Mad Max is offline
post #4 of 13 (permalink) Old 03-15-2009, 03:03 PM Thread Starter
chris 0.'s Avatar
Re: will it work?
anyone else have input?
chris 0. is offline
post #5 of 13 (permalink) Old 03-16-2009, 06:48 PM Thread Starter
chris 0.'s Avatar
Re: will it work?
well i bought the lift! i hope it works! i will start on it thursday!
Thanks for the replies!
Chris 0.
chris 0. is offline
post #6 of 13 (permalink) Old 03-16-2009, 06:56 PM
The Fireman
big_stroker's Avatar
Re: will it work?
Not sure but you might be able to use the stock track bar bracket and just get an adjustable track bar
big_stroker is offline
post #7 of 13 (permalink) Old 03-16-2009, 07:17 PM
Banned
Re: will it work?
Am I the only one that thinks the easiest solution would be a drill bit?
Charles is offline
post #8 of 13 (permalink) Old 03-16-2009, 07:21 PM
HRT Performance
HotRodTractor's Avatar
Re: will it work?
That sir is crazy talk.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #9 of 13 (permalink) Old 03-16-2009, 07:22 PM
Banned
Re: will it work?
Too easy huh.
Charles is offline
post #10 of 13 (permalink) Old 03-16-2009, 09:46 PM Thread Starter
chris 0.'s Avatar
Re: will it work?
Too easy huh.
i thought about that. would that be a problem? not safe? i would have to look at the situation.
chris 0. is offline
