Clutch recommendations? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 49 (permalink) Old 03-14-2009, 05:00 PM Thread Starter
So, I just got my block and heads back from the machine shop. It was bored .020 and everything gone through. I've got 80hp injectors coming and am gonna put a tuner on it. Also have big head and compressor wheel coming. Nothing major, but at 250,000 I'm sure the clutch is not gonna hold. I don't wanna spend a ton of money, but I want something reliable and rated for what I'm doing. A cousin of mine runs centerforce, but I see alot in Google about Southbend. I know it basically comes down to preference, but who's got the best bang for my buck?
strokinsince'95 is offline
post #2 of 49 (permalink) Old 03-14-2009, 05:33 PM
JHill's Avatar
Re: Clutch recommendations?
I beat the heck out of a SB con OFE, SB cutomer service is top shelf.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #3 of 49 (permalink) Old 03-14-2009, 05:54 PM
Tampa450's Avatar
X2 on SouthBend Clutch
I had one in my 550,
It was so long ago I couldnt tell you exactly which one.
I had the same experience with them
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
post #4 of 49 (permalink) Old 03-14-2009, 05:57 PM
krankin's Avatar
x2 for southbend. I have the con O and it holds my DP 140hp tune well. I dont know how well it will hold bigger injectors, but I think most people on here run the OFE. The pedal pressure with a SB should be reduced over the stock clutch too.
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
krankin is offline
post #5 of 49 (permalink) Old 03-14-2009, 06:07 PM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
when i get the money i will be buying a southbend as well
{95 F250 Powerstroke XLT} 5 spd, injectors by Farmers Diesel, tunes by tyrant diesel, AFE stage 2 intake, custom intercooler, 3" down pipe to custom 5in stack. EBPV break, custom electric fuel system, IDM mod by mattymx, CCV mod, D60 with F-Superduty springs, diprocol EGT, Boost and Fuel PSI guages.
joebob3093 is offline
post #6 of 49 (permalink) Old 03-14-2009, 06:13 PM
JHill's Avatar
joebob3093
Off Topic: are you hearing much over your way about the Redmond pull in May?
sorry for the derail
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #7 of 49 (permalink) Old 03-14-2009, 06:16 PM
2nd class citizen
1snotrocket's Avatar
x3 south bend con o fe.works great for me and has good street manner.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #8 of 49 (permalink) Old 03-14-2009, 07:23 PM
Fat Kids Rule!
House's Avatar
Send a message via AIM to House
X4 on sbc
Joe "House" Kupferschmid
1995 F250 7.3 2.6 zf6 Puller
2006 Chevy 3500 CC DRW LBZ, Tow Slut
SOLD:2000 F350 harvester of sorrow
House is offline
post #9 of 49 (permalink) Old 03-14-2009, 08:15 PM
Southbend Con O here. I think they are good to 350 rwhp. So if you plan on going past that, you will likely have to step up.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #10 of 49 (permalink) Old 03-14-2009, 08:26 PM Thread Starter
So, is anybody running anything besides SB? just curious, want to get as much feedback as possible. By my best estimations I'll be turning about 500, so the con fe is my best bet?
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/14-7-3l-power-stroke-aftermarket-performance/26385-clutch-recommendations.html
Posted By For Type Date
Clutch break-in question - Dodge Cummins Diesel Forum This thread Refback 03-14-2016 03:49 PM
