PCM Code - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-13-2009, 09:58 PM Thread Starter
Thomas7.3psd's Avatar
Question PCM Code
Im about to order my chip and i need the pcm code where is it? i was told its under the hood close to were the pcm connects, on a plate of some type i found a kinda diamond shape plate thats black, above the pcm plug. is this it?
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #2 of 6 (permalink) Old 03-13-2009, 10:10 PM
Butt-Head
PHPDiesel's Avatar
Re: PCM Code
That's not it....
Either remove the black cover on the PCM next to the parking brake mechanism or use a telescoping mini mirror to look at the PCM connector housing towards the fender.....down below and to the left (driver's side) of the master cylinder.
Cody
PHPDiesel is offline
post #3 of 6 (permalink) Old 03-14-2009, 02:02 AM Thread Starter
Re: PCM Code
looks like to pull the black cover off i would need to remove the whole pcm(?)...i looked at maintains install vid and i can see where the code would be(i belive) so im gonna give the mirror a shot first. Thanks man.
post #4 of 6 (permalink) Old 03-14-2009, 02:11 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: PCM Code
I'de just yank it out so theres no mistakes,its easier than you might think.(better safer than sorry)
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #5 of 6 (permalink) Old 03-14-2009, 02:31 AM
Village Idiot
southmike's Avatar
Re: PCM Code
here is what you need.
http://dev.dp-tuner.com/wordpress/wp...r-pcm-code.pdf
southmike is offline
post #6 of 6 (permalink) Old 03-14-2009, 01:50 PM Thread Starter
Re: PCM Code
got it.Thanks for that help guys.
