EARLY 99ers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 03-12-2009, 03:52 PM Thread Starter
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
EARLY 99ers
To all the early 99 owners on here or anyone with knowledege on this turbo.
Who or does anyone on here run BDP Domminator 66 turbo?
It says with a stock turbo you run 750CFM and the d66 runs 1050 CFM.
And its claiming 100CFM over the H2E setup. Are these real acurate numbers given or just high ball numbers?
If anyone has any good input on this id appreciate it! Thanks!
SMOK'N BLUE STROKER is offline
post #2 of 31 (permalink) Old 03-12-2009, 04:05 PM
blue99sd's Avatar
Re: EARLY 99ers
Im running the d-66 on mine.I can tell a big difference in spool up and with the injectors Im running makes a good combination. As far as knowing numbers you need to talk to Bean (Beans Diesel Performance) he helped me out.
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #3 of 31 (permalink) Old 03-12-2009, 04:11 PM
OBS junkie
Cat_Rebel's Avatar
Re: EARLY 99ers
The D66 is mostly a modded Van Turbo in all truth but seem to work well & like any other stocker is rebuildable. Don't know but you might have some spool problems up in the hills.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 31 (permalink) Old 03-12-2009, 04:32 PM Thread Starter
HHAUL'N STROKER
Re: EARLY 99ers
You think the higher elevation is going to make harder spool ups? Has anyone had this problem?
post #5 of 31 (permalink) Old 03-12-2009, 05:54 PM
Keyboard Thug
Big Bore's Avatar
Re: EARLY 99ers
It's all in the tunes. I'm travel from 8000 to 5280ft and back every day, then up over 10,000 and back down to 9000 on the weekends. Just back off the fuel and you are good. If you see heavy smoke and it lags, cut the fuel.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #6 of 31 (permalink) Old 03-12-2009, 06:03 PM
Irate Sales Guy
greenbeast's Avatar
Re: EARLY 99ers
Those are real numbers. The D66 is a great upgrade for the early 99 for a drop in turbo.
Cat...van turbo?
97 F-250 CC 350/200's, Intercooler, Billet S468, T-4 mount, BTS trans, Irate Electric Fuel, BTS Dual Pumps, Water Meth, NOS, ARP studs, Comp 910 springs, Gearhead tuning.
503-435-9599 Call or Text!
greenbeast is offline
post #7 of 31 (permalink) Old 03-12-2009, 06:27 PM
Village Idiot
southmike's Avatar
Re: EARLY 99ers
the d66 is the only drop in for an early 99.
they out flow a regular h2e but will not hold up well with large injectors.
stage 1 and 2 are great , b codes and big hybirds may be a bit much on it.
the h2e has a kit for early 99's from dieselsite and elsewhere but is 2x the cost.
southmike is offline
post #8 of 31 (permalink) Old 03-12-2009, 06:32 PM Thread Starter
HHAUL'N STROKER
Re: EARLY 99ers
Would small hybrids be ok to run on D66?
post #9 of 31 (permalink) Old 03-12-2009, 06:35 PM
Pulling sled for hire
ParkerFly's Avatar
Re: EARLY 99ers
A few guys are out there running them, including rtxcoon and 3starJ.R. on this site. I think they've had good luck with them, the main thing is holding your boost psi down..
Justin
Justin
#62
'97 F-250 - 255k
463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP.
ParkerFly is offline
post #10 of 31 (permalink) Old 03-12-2009, 06:37 PM
Village Idiot
southmike's Avatar
Re: EARLY 99ers
good question.
strokin early 99 ran bcodes on his truck for a year or so iirc.
howard did pulling comps etc..never had problems with it.
and said he liked it a lot. he went to a larger modded h2e and sold his d66 to another guy.
From what i recall it lasted a week or so, and he had beans do a rebuild on it .
So either it was a ticking time bomb, got damaged in the mail user install error etc who knows.
If it was me I would ask bean on the phone, since they sell injectors etc.
since all my info is second hand internet hearsay
