CFM Y pipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 48 (permalink) Old 03-09-2009, 03:23 AM Thread Starter
01platinum's Avatar
CFM Y pipe
This looks like a cool product and a very good idea. Wonder how well it will work.
Stock Y pipe VS CFM Plus Y pipe
Real Diesels Have Stacks
New Tunes by Matt @ Gear Head - Auto Meter Gauges from Nate @ PTP
Air Dog II Fuel Pump
First RR Fuel System built by hand @ Murff Racing
More to come soon..........
01platinum is offline
post #2 of 48 (permalink) Old 03-09-2009, 04:01 AM
Re: CFM Y pipe
Waste of 400 dollars IMO.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #3 of 48 (permalink) Old 03-09-2009, 04:19 AM
Ticking time bomb
Re: CFM Y pipe
groomzybanshe is offline
post #4 of 48 (permalink) Old 03-09-2009, 11:33 AM
DZL JIM's Avatar
Re: CFM Y pipe
Ford wants $600+ for the OBS guys that are looking for one to convert to 3" intakes.
This might be an option for some...
DZL JIM is offline
post #5 of 48 (permalink) Old 03-09-2009, 11:52 AM
Dirty South Strokers
bigwhite7.3stroker's Avatar
Re: CFM Y pipe
WOW that thing is pricey yet nice looking piece
TN BB, 238cc's, 910's, Bellowed Up-pipes, Non-EBPV Pedistal, built tranny, Traction Bars, 4.56's, 6.0 IC, Water/Meth,Jody's Tunes
Taylor
bigwhite7.3stroker is offline
post #6 of 48 (permalink) Old 03-09-2009, 12:21 PM
Banned
Re: CFM Y pipe
Here's my question...
Does it literally separate the two? If so, it's the dumbest pos I've ever seen. For starters, what is the total effected surface area between the two ducts? 4 square inches? With no fins, nothing. The amount of heat that's going to travel through, and actually make it's way into the intake air is not worth anyone's time in the first place....
Secondly, and more importantly...
The BIGGEST thing the stock upper intake manifold does is connect the inlet side to the compressor outlet, which is BOLTED to the engine via the turbo pedestal. This keeps the intake side from lifting off the lower manifolds under boost and popping out of the silicone couplers. JUST like the hypermax or similar intakes love to do. By having it all tied together it CANNOT lift and pop out of the boots because it's mechanically tied to the engine.
By separating them like that, you gain NOTHING and lose EVERYTHING. I'm sure they will tell you the problem is the inferior stock couplers once that starts happening.... Yet I have run over 90lbs of boost on the same stock couplers that have been on my engine since it was made in 1999.
If they still tied them together to stop this, what was the point again? According to them?
(This is complete bs. The ability of the tube wall to put heat into that air is not worth anyone's time)
IMO of course.
Charles is offline
post #7 of 48 (permalink) Old 03-09-2009, 02:30 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Re: CFM Y pipe
And all those before him in this thread....
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #8 of 48 (permalink) Old 03-09-2009, 04:14 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: CFM Y pipe
. I wondered how long it would be before Chuck jumped on this. I think if I was gonna do something like that I would take two stock ones and just cut them apart making two peices, but I agree with Charles. The whole thing is made liek that for a reason, and I don,t think you would see much of a drop in temps over the stock configuration.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #9 of 48 (permalink) Old 03-09-2009, 04:32 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: CFM Y pipe
Obviously "the Charles" has spoken out of his "inaccurate information hole" and as such posted an invalid epinion
and that goes for everybody else that agreed with him without taking the time to investigate the product being discussed.
IDE's
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #10 of 48 (permalink) Old 03-09-2009, 04:41 PM
Hater Club
Dirk's Avatar
Re: CFM Y pipe
IDE's
do you sell these?
(not being a smartas$)
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
