Up Pipe Bellow? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-07-2009, 03:23 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Up Pipe Bellow?
Are these the bellows everyone is using for the up pipes? Also would it be a good idea to put a 3" one in my intermeadiate pipe to allow for expansion?
http://www.atpturbo.com/Merchant2/me...egory_Code=FLX
Thanks
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 12 (permalink) Old 03-07-2009, 03:25 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: Up Pipe Bellow?
yup thats what i have, but different measurement, and after about 500 miles i see some soot poking through the braiding...???
Stock
PowerstrokeJunkie is offline
post #3 of 12 (permalink) Old 03-07-2009, 03:28 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: Up Pipe Bellow?
So they wont work then because of the drive pressure. I see on the page it says for downpipes.
Also found these. http://www.verociousmotorsports.com/...xible-Coupling
Tow Mule
post #4 of 12 (permalink) Old 03-07-2009, 06:48 PM
Banned
Re: Up Pipe Bellow?
The one I used is not braided. It's purely a bellows. It has been working fine for a couple years now. It is 304 stainless. And it has a much better ratio of diameter to length than most.
You'll pay for them though...
I gave just over 200 dollars for that one bellow.
Charles is offline
post #5 of 12 (permalink) Old 03-07-2009, 07:10 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: Up Pipe Bellow?
Dam I found a 3" bellow that was braided that was only 4" long. Also where is a good source to get the v-band kits for up pipes?
Tow Mule
post #6 of 12 (permalink) Old 03-08-2009, 12:02 AM
DZL JIM's Avatar
Re: Up Pipe Bellow?
I'd get the ones from verocious with the interlocking liner.
Verocious and atp turbo have the v-band stuff...
I've never seen a bellow in an intermedaite pipe. Although most are very short and a bellow wouldn't do much. If it's a long pipe like Charles' I probably would.
DZL JIM is offline
post #7 of 12 (permalink) Old 03-08-2009, 12:17 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Up Pipe Bellow?
what about these???
http://www.mandrelbending-tubefabric...ssories_09.gif
Ron's power stroke is offline
post #8 of 12 (permalink) Old 03-08-2009, 12:22 AM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Re: Up Pipe Bellow?
Charles, or anyone, IYO would a bellow be necessary with ceramic coating? I believe UNCOOL, and Jim both run up pipes without bellows of any kind. Didn't know if it would pry your manifolds off the block with ceramics, or in this case push the two turbos away from eachother.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #9 of 12 (permalink) Old 03-08-2009, 04:01 AM
I make smut cry
Re: Up Pipe Bellow?
No AC Charles?........
Cowboy Steve
Powerstroked162 is offline
post #10 of 12 (permalink) Old 03-08-2009, 04:17 AM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: Up Pipe Bellow?
No bellows in my install, just the factory up-pipe collectors.
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
