Tymar and filter minder - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-06-2009, 01:41 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
I still have the filter minder on the 99 SD with the Tymar setup. I have reset it a couple times now and it will suck it thing down pretty quick. I dont think my filter has too many miles on it, but it might be dirty I guess. I thought that Tymar would flow enough that it would have to be restricted pretty bad to suck down that filter minder.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 18 (permalink) Old 03-06-2009, 02:02 PM
Re: Tymar and filter minder
I have never seen it move on any Tymar setup?? Maybe your minder is bad?
OBSWIZ is offline
post #3 of 18 (permalink) Old 03-06-2009, 03:53 PM
Junior Mint
The proper location of the filterminder is somewhere on the intake tube between the filter and the turbo.
Many people mistakenly install the filterminder on the end of the cone filter where the restriction is way less obviously because you are technically not between the filter and the turbo.
If you are sucking down your filterminder there is noticable power to be had by figuring out a filter set up that does not cause your minder to move at all. I had to get two filters on mine to accomplish this and it offered a huge improvement in my case. It felt like I dropped a turbine housing size it spooled up so much better, plus I gained boost up top and it smoked less.
I'm officially...Stroke-less.
Suns_PSD is offline
post #4 of 18 (permalink) Old 03-07-2009, 04:05 PM
Thomas7.3psd's Avatar
Where would i get the tymar filter? or something like it? Thanks
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #5 of 18 (permalink) Old 03-07-2009, 04:53 PM
All done now
Arisley's Avatar
WIX 6637, a short piece of 4" exhaust tubing, and a 4" hose clamp.
Your local auto parts store, and Home Depot for the clamp.
Arisley is offline
post #6 of 18 (permalink) Old 03-07-2009, 04:55 PM
HMBUILDER4U2004's Avatar
get a 6637 filter from napa works great and just fab up a 4inch intake to it
HMBUILDER4U2004 is offline
post #7 of 18 (permalink) Old 03-07-2009, 04:55 PM
post #8 of 18 (permalink) Old 03-07-2009, 05:11 PM
Cool Thanks.sorry to steel the thread. As you where. Thomas
post #9 of 18 (permalink) Old 03-07-2009, 07:10 PM
Have you tried blowing the filter out with some low air pressure? don't get too crazy or you could damage the paper element. What kind of conditions do you drive in?
calebgriffin31 is offline
post #10 of 18 (permalink) Old 03-08-2009, 03:57 AM
Have you tried throwing the minder in the trash? Or at least the spare parts bin. What a POS anyway. It's a spring. Get rid of it and fit a gauge if you are that worried about it.
Tenn01PSD350 is offline
