Opinion on head studs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 03-05-2009, 12:42 AM Thread Starter
Peterbiltman79's Avatar
I have a 2003 F350 7.3l I got a Edge juice with attitude module and when I have it turned all the way up ive seen the boost at 23-24 psi. I dont know what the stock range is. I want to get a ARP stud kit for it then i dont have to worry about the head blowing off. But until I get it i just want to make sure im not pushing the limit of the head bolts. Ive heard the 6.0L had problems with there head bolts and i had a friend that had his head come right off the motor in his 6.0L. Any opinions or comments will help
Peterbiltman79 is offline
post #2 of 23 (permalink) Old 03-05-2009, 12:44 AM
Hater Club
Dirk's Avatar
Re: Opinion on head studs
7.3?
I'll bet you'll window that block when you chunk a rod before you lift the heads. Save your money. Replace the PMR's with forged rods and install head studs at that time.
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #3 of 23 (permalink) Old 03-05-2009, 01:10 AM
Deputydog's Avatar
Originally Posted by Dirk View Post
7.3?
Deputydog is offline
post #4 of 23 (permalink) Old 03-05-2009, 02:00 AM
JHill's Avatar
with stock fuel 18-20#.
set at 32# here, crossing fingers and toe's till funds allow.
IIRC 40# max. seen a couple lift around 30#.
.02
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 23 (permalink) Old 03-05-2009, 02:03 AM
Hater Club
Dirk's Avatar
.02
Peak cylinder pressures/timing will kill head gaskets before boost. 40-45psi is a safe limit.
Dirk is offline
post #6 of 23 (permalink) Old 03-05-2009, 02:05 AM
jaybuller's Avatar
ive heard that the 7.3s dont realy need studs till you get big cylinder pressures not just high boost. with that said i had a pmr and i went ahead and replaced the rods with forged and just got stock headbolts and gaskets all because i hear the 7.3s dont blow head gaskets like the 6.0s do. Plus i think its all in the tuning wether you get high cyleinder pressures or not. someone else knows a lot more than me about it and there is a post somewhere in hear about it i just cant find it.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #7 of 23 (permalink) Old 03-05-2009, 02:06 AM
jaybuller's Avatar
dirk i think you and i are on the same page, i think we typed at the same time you azz..lol
post #8 of 23 (permalink) Old 03-05-2009, 02:17 AM
JHill's Avatar
as well as chuck rods
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #9 of 23 (permalink) Old 03-05-2009, 02:24 AM Thread Starter
Well now im not worried about the head bolts i just got to worry about throwing a rod. great thats what I need lol thanks everyone for your info
post #10 of 23 (permalink) Old 03-05-2009, 04:05 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Beat on that thing as hard as you want to, that Edge is not extreme enough to blow a head gasket or chuck a rod on it's own.
Stock
PowerstrokeJunkie is offline
