Wastegate actuator red vacuum tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-04-2009, 04:09 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
So after talking with David last week I checked to see if the red tube was connected and there it was in place, so on the advice of a friend I disconnected it and placed it over one of the IC boot clamp bolts. Hopefully I will see some top end boost gains. Previous boost was limited at 25-28psi. If that doesnt help I'll just wire the dang thing shut. Not trying for 60 psi, but would definately like to be over 30psi.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 19 (permalink) Old 03-04-2009, 04:12 PM
Banned
Re: Wastegate actuator red vacuum tube
Fwiw, it's a pressure signal line, not a vacuum line.
Charles is offline
post #3 of 19 (permalink) Old 03-04-2009, 04:15 PM
2010 BOB Points Runner up
Dieselfever's Avatar
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
This is on the '99 in your sig? I have a guy local that bought a used 38R and with some S175/30% it would top out at 27-28 psi. I even went and shortend the wastegate rod up as short as it would to where I could put it back on the pin and it didn't change.
There was a small exhaust leak I fixed and went back and made sure everthing was lined up and not leaking and now it will do 31-32psi but that's it. And EGT's don't seem near as low as they should be, but that might be the wonderful design of the splitshot that he didn't want to convert from.
-Michael
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
Dieselfever is offline
post #4 of 19 (permalink) Old 03-04-2009, 04:19 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
-Michael
Hmmmm.
Big Bore is offline
post #5 of 19 (permalink) Old 03-04-2009, 04:36 PM
I also pressure checked the charged air pipes and cooler to 30 psi on that truck and all was fine.
-Michael
Michael
post #6 of 19 (permalink) Old 03-04-2009, 04:51 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
-Michael
Hmm, I borrowed a real slick pressure tester from Pocket last week, no chance to use it yet. I'm pretty sure I dont have a boost leak. Bellowed uppies are good, and fixed the EBPV tube leak, so no exhaust leaks. BTW, a BD exhaust brake is an excellent exhaust leak detector.
Big Bore is offline
post #7 of 19 (permalink) Old 03-04-2009, 06:01 PM
I make smut cry
-Michael
I can do 42lbs. I have my gate set at 30lbs.
Cowboy Steve
Powerstroked162 is offline
post #8 of 19 (permalink) Old 03-04-2009, 07:21 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
Cowboy Steve
What injectors?
Big Bore is offline
post #9 of 19 (permalink) Old 03-04-2009, 07:58 PM
I make smut cry
180's
Cowboy Steve
post #10 of 19 (permalink) Old 03-04-2009, 08:24 PM
That's what has me, some guys with 160-180cc injectors can swing the piss outta these things and others are lucky to break 30. Granted every truck is different and things come into play like specific nozzle, trans, gearing, and Altitude.
-Michael
Michael
