Filled Block and Occasional towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 03-04-2009, 01:35 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Getting closer to finally getting the motor. I've talked to Charlie and he says it "shouldnt" be an issue as he pulls a skidsteer with his. Anybody else have a filled block and pull occasionally?
There is a possibility of pulling a 10k lb travel trailer a few times a yr a max of about 80 miles one way. Also gotta do this soon:
roughly 6-7k lbs
What about a secondary oil cooler for piece of mind?
PTSUPERD is offline
post #2 of 35 (permalink) Old 03-04-2009, 02:50 PM
Re: Filled Block and Occasional towing
Id run an oil temp gauge and see how the temps do. If the temps get too high add some sort of oil cooler.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #3 of 35 (permalink) Old 03-04-2009, 03:06 PM Thread Starter
Banning Smut
PTSUPERD's Avatar
Adding an oil temp gauge for sure.
PTSUPERD is offline
post #4 of 35 (permalink) Old 03-05-2009, 02:58 AM
2nd class citizen
1snotrocket's Avatar
a little off subject but that's a nice looking truck.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #5 of 35 (permalink) Old 03-05-2009, 03:48 AM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Add an oil temp and water temp gauge if it were me, and i plan on getting a decent size A/O cooler and plumb it in the return line from my bypass oil filter that dumps back into the crankcase anyway. Advance has some nice cheap 1-2^2 coolers
Stock
PowerstrokeJunkie is offline
post #6 of 35 (permalink) Old 03-05-2009, 04:23 AM
What else?
smokyred's Avatar
Are you also moving the heater hose back on the pass. side and running an extra line from the driver's side like Charles? I notcied the other day that Excursions run similar to that from the factory, they have a nice steel crossover tube from the driver's side.
Dave
smokyred is offline
post #7 of 35 (permalink) Old 03-05-2009, 04:25 AM Thread Starter
Banning Smut
PTSUPERD's Avatar
Dave
Wasnt planning on it...but thanks for mentioning that. Something to look at for sure.
PTSUPERD is offline
post #8 of 35 (permalink) Old 03-05-2009, 04:26 AM Thread Starter
Banning Smut
PTSUPERD's Avatar
'preciate it!
PTSUPERD is offline
post #9 of 35 (permalink) Old 03-05-2009, 05:45 AM
I make smut cry
Truck is nice but I hear the owner has been called a "cockshucker" a time or two
Dave
Im not following you, please explain......
Cowboy Steve
Powerstroked162 is offline
post #10 of 35 (permalink) Old 03-05-2009, 05:29 PM
DarkShadowDiesel's Avatar
Cowboy Steve
You move the heater hose from the front of the pass side head to a port farther back and tie it in with a port from the driver side head to increase coolant flow
2002 F250
DarkShadowDiesel is offline
