Superchips 1805 vs Custom Chip ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 03-04-2009, 11:25 AM Thread Starter
Can you explain to me why a Custom Chip is so much better than the Superchips 1805?
For a little background...I have 3 friends/mechanics who own 8 Super Duty 7.3 Power Strokes between them. They also work on them all day. The only mods they do to their own trucks is the Superchips 1805 and put it on the Tow Safe Tune(+47 horse and +82 torque)
My truck is stock and will most likely stay that way for now since it is a work truck.....Here is my goal with any tuner:
1. Keep the power at a safe level and not hurt the motor
2. Grab a little more power-no desire to have a flip chip that will allow me to switch to an insane power level at a moments notice(Lack of Will Power)
3. Not hurt the motor
Based on my goals...is a custom chip going to be that much better and if so can you please explain how?
Thanks
2003 F-350 XLT Supercab-Black 7.3/Auto
1990 Mustang 5.0-Black 308 TW Heads, Vortech S Trim, Meth Injection, 5-speed
2009 Harley Street Glide-Black 6 speed
only90s is offline
post #2 of 22 (permalink) Old 03-04-2009, 11:44 AM
4cstr's Avatar
Re: Superchips 1805 vs Custom Chip ?
Because the SC tri-tune is written full of generic tunes...a one-size fits all type of thing.
For the masses...it really isn't that bad. Thats what I began with. But...with a chip (insert your favorite tuner here)...they can write tunes specifically for your truck. What will get the best mpg for a 2003 7.3L truck...may not be what gets the best mpg for a 99 7.3L...and a tuner(ie somebody who has custom tunes) knows this. The SC tri-tuner doesn't.
early 99, old, slow but paid for.
4cstr is offline
post #3 of 22 (permalink) Old 03-04-2009, 12:32 PM
The Fireman
big_stroker's Avatar
And the drive ability is so much better with a custom tuned chip... and most the time safer and better for the motor and tranny
big_stroker is offline
post #4 of 22 (permalink) Old 03-04-2009, 05:19 PM
Genius, when I drink
ditch_dawg's Avatar
Trans shifting and fuel mileage compared to my last 'off the shelf' chip.
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #5 of 22 (permalink) Old 03-04-2009, 05:41 PM
secondarychaos's Avatar
The superchips won't adjust transmission pressures, which can be rough on it. that's the biggest difference for me.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #6 of 22 (permalink) Old 03-04-2009, 06:46 PM
The biggest thing with a chip is the ability to change power levels on the fly.... Also IMO the tuning for the 7.3 by the big guys like superchips and others were really ever turned up all the way because people would still try to tow on the hottest setting and they knew that. Also flash tuners always start with your stock file wich may not give good shifting and lockup characteristics. A custom chip can give you the PMT1 shifting characteristics that everyone wants. You can't get this with a flash programmer unless you started with a PMT1 truck.
mattr66 is offline
post #7 of 22 (permalink) Old 03-04-2009, 06:52 PM
Lovin the Tuna
RedSmokey's Avatar
To the OP, you can get custom tunes on a SCT and load the tunes the same way you load a superchip, no flipping between programs, you just plug into the OBDII port and load it, difference is better tunes. Like all stated above, the transmission get tunes, usually better drivability and its specific to your truck.
2001 F250
2000 F250
RedSmokey is offline
post #8 of 22 (permalink) Old 03-04-2009, 06:57 PM
theSLEEPER's Avatar
I think the transmission is THE BIGGEST reason to get a custom chip. Let your buddys run what they will. Then custom tune your truck and see who has the best power/dependability/drivability.
theSLEEPER is offline
post #9 of 22 (permalink) Old 03-04-2009, 07:07 PM
PowerstrokN805's Avatar
Send a message via AIM to PowerstrokN805
Yeah I've had two different super chips, the micro tuner(1805) and the cortex which I'm still running, and to be honest its ruining my transmission. It was rebuilt about 15k miles ago and i can tell how much its still wearing on it. Even when your just cruising it has shifting points like your racing and causes a lot of DTC. But the power difference in okay, i still would rather have a custom chip than a programmer.
1999.5 F-250 Crew Cab Short bed 4x4
Superchips Cortex, K&N Air filter, 4inch MBRP exhaust, and 7inch lift.
PowerstrokN805 is offline
post #10 of 22 (permalink) Old 03-04-2009, 08:43 PM
aklim's Avatar
Superchips, Hyperjunk, etc, etc is like getting a suit for a 45 yo white male. Well, to do that, you get a stretchy suit that will expand.
Custom chip (DP-Tuner for example) is like you telling the tailor your ht, wt, etc, etc.
Live Tuning is like the tailor measuring your each and every part and making sure it fits exactly.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
