Oil filter and cooler on the HPOP? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 03-04-2009, 02:36 AM Thread Starter
So I've been thinking about running a cooler on my return line that dumps back into the oil reservoir. Anthony did this on his truck, and it turned out great.
Then I started thinking what an oil filter (FS2500 or something similar) would do if added before the cooler. Would it be too much of a restriction? Seems like if it didn't cause a restriction, it would be a good way to clean the oil before heading back to the injectors.
Any ideas?
99 F350 CCLB
skav is offline
post #2 of 22 (permalink) Old 03-04-2009, 02:52 AM
What else?
smokyred's Avatar
Re: Oil filter and cooler on the HPOP?
The cooler would be a good idea, IMO, but I don't think the filter would be needed, as you already have a screen in the HPOP resivior gasket that catches particles before they go to the HPOP.
Dave
smokyred is offline
post #3 of 22 (permalink) Old 03-04-2009, 02:55 AM
hotstik's Avatar
Dave
The screen is on late 99-up motors. Early 99 and OBS motors don't have it.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #4 of 22 (permalink) Old 03-04-2009, 03:11 AM Thread Starter
I don't think that I have a screen on my truck. Have you thought about running a filter on your truck?
99 F350 CCLB
skav is offline
post #5 of 22 (permalink) Old 03-04-2009, 03:20 AM
hotstik's Avatar
As long as the filter doesn't add a significant amount of restriction to the system, it might be beneficial.
Extra filtration and extra cooling usually seem to be a good thing. On top of that, the filter would be one more place for the oil dumped through the IPR to "mellow out" before heading back to the reservoir.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #6 of 22 (permalink) Old 03-04-2009, 03:24 AM
theSLEEPER's Avatar
What kind of cooler are you thinking?
And how did it feel different?
Seems like hotter, thinner oil works better, right?
What's the advantage of the cooler?
Not knocking or anything... just curious.
theSLEEPER is offline
post #7 of 22 (permalink) Old 03-04-2009, 03:28 AM Thread Starter
the filter would be one more place for the oil dumped from through the IPR to "mellow out" before heading back to the reservoir.
That was also what I was thinking. The filter and cooler would also give additional capacity to the entire oil system too (as if over 4 gallons wasn't enough).
Any idea how restrictive the bypass filters are?
99 F350 CCLB
skav is offline
post #8 of 22 (permalink) Old 03-04-2009, 04:00 AM
Banned
If you're talking about running it on the IPR return line.... I wouldn't be too worried about restriction, lol.
If the filter became too restrictive, the 3000 or so psi ICP would easily "resolve" that issue no prob. I have no doubt that the oil would make it's way out of the IPR.
Dont' know that the filter would be in one piece for long if that happened though.
FWIW, I don't think the FS2500 is designed for that much flow. That would be utilizing it in a way where it's flow must be maintained. It was desgined to be used as a bypass, not a full flow unit. Even though it would not be taking full engine oil flow, it would be taking 100% of the expected volume leaving that line, which makes it full flow for that application. If the element stopped up, sh*t would get ugly in a hurry (assuming the element could have supported the oil flow rate when clean).
Charles is offline
post #9 of 22 (permalink) Old 03-04-2009, 04:21 AM Thread Starter
This is the line that I'm thinking of. Instead of dumping back into the res, sens the oil to the filter then cooler, and then back to the res. Only a bit cleaner and cooler.
99 F350 CCLB
skav is offline
post #10 of 22 (permalink) Old 03-04-2009, 04:24 AM Thread Starter
Didn't think about the whole "plugging up the filter" part. That would really suck .
Is there a filter that could handle the pressure w/o coming apart?
Maybe better off w/ just the cooler. Still giving the oil a chance to simmer down a bit before putting it back to work again.
99 F350 CCLB
skav is offline
