Sideways on the highways - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 03-03-2009, 05:32 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
I've had the 99 SD in my sig sideways a few times while trying to accelerate on an uphill curve. I can't remember this ever happening with the OBS. Now the SD has approx 75 more HP. Is that enough of a difference? The first couple times I was still running the 265 all season Michelins, but it happened this morning with brand new 285 all terrains. The vehicle length is quite a bit different, OBS LB CC vs SD SB SC, maybe 3 feet difference? Not sure if length matters except it is definately more dramatic going sideways in the shorter vehicle, especially on dry pavement. I have also noticed the LS diff locks up pretty quick in the SD>
Is there anything I can do? Will wider tires help, or just give more flotation and therefore less psi down on the ground? I've been looking at a leveling/lift for the front shackles so I can fit 315's/35's. Maybe that will help, dunno.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 26 (permalink) Old 03-03-2009, 06:03 PM
theSLEEPER's Avatar
Re: Sideways on the highways
Anytime the road has any dew or rain I have a hard time... and that's with 15.50's... just have to adjust driving...
theSLEEPER is offline
post #3 of 26 (permalink) Old 03-03-2009, 06:40 PM
fbilly420's Avatar
little less pressure on the skinny pedal.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #4 of 26 (permalink) Old 03-03-2009, 06:45 PM
A Ghost these days...
farm boy's Avatar
Mine is a B to drive when the road is damp or wet. And ive got 35X12.50's. Just got to slack off on the GO pedal.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #5 of 26 (permalink) Old 03-03-2009, 06:47 PM
throttle jockey by trade
hookin78's Avatar
I did this just after I installed my stage twos and was ticketed with a wreckless operation, after doing a 180 in-front of a sherriff just over the overpass, I went to court, told the judge that I had just put in new bigger injectors and tuning and was just getting used to it, he told me I needed to adjust my driving habits now, so yes we at times need to adjust our driving habits.
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #6 of 26 (permalink) Old 03-03-2009, 07:10 PM
racehauler's Avatar
Or run a less agressive tune...
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #7 of 26 (permalink) Old 03-03-2009, 07:45 PM
28 cent #2
daryl4412's Avatar
just keep your foot out of it. I know plenty of ppl with 500-600 hp trucks and they don't have problems in the rain. You just have to be responsible with your driving and don't get in a hurry. My dd which is a ford escort will spin in the rain......
daryl4412 is offline
post #8 of 26 (permalink) Old 03-03-2009, 09:19 PM
Banned
If it starts sliding to the right, steer right.... if it starts sliding left, steer left....
And keep your foot planted for fun. Otherwise, I refuse to believe you can't anticipate when you are about to be giving more throttle than you have traction for given the road you can plainly see with your eyes.
Have fun, if you choose, else drive like a normal person.
My wife has no problem driving my truck in the rain. Of course she wouldn't stand the throttle to the firewall and expect anything other than complete caos either.
Charles is offline
post #9 of 26 (permalink) Old 03-03-2009, 09:33 PM
secondarychaos's Avatar
Or if you really want traction, i'd look into a better set of all weather tires...
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #10 of 26 (permalink) Old 03-03-2009, 11:53 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Or, put it in four wheel drive?
Stock
PowerstrokeJunkie is offline
