replace rear hpop only on dual..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-03-2009, 05:41 AM Thread Starter
train wrecker
pusnboots's Avatar
Unhappy replace rear hpop only on dual.....
...pumps, in the truck? can it be done? i just blew the back fitting off the rear pump, and was wondering if you can just take that pump off and replace it? or do you have to remove the whole thing again?
i'd be sooooo much easier to just pull the back one off and replace.
any thoughts?
brent
02 f250 4"superlift,35toyo mts ,6637intake,5"exhaust,dptuner, aihdelete, gt38r bb, stealth, scan gauge,evans coolant&dieselsite filter,203stat with billet housing,autometer pyro,boost vegistroked
pusnboots is offline
post #2 of 7 (permalink) Old 03-03-2009, 01:54 PM
fbilly420's Avatar
Re: replace rear hpop only on dual.....
I am sure you could get it off but putting it back on will be the hard part. I would just pull both of them as an assembly and replace pump and reinstall as an assembly.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 7 (permalink) Old 03-03-2009, 08:19 PM
PSN Pretender
907DAVE's Avatar
nope, the allthread that hold the pumps togeather is too long to be removed in the engine valley.
907DAVE is offline
post #4 of 7 (permalink) Old 03-03-2009, 09:55 PM
Banned
Any reason why you think it blew? What peak pressure were you, or had you been running recently?
Overtightened on assembly? I find them tight as hell all the time. Sometimes I think people forget it's ORB, and it's an aluminum case.... Some of them are about as tight as I would expect a pipe thread fitting to be in a steel manifold.
Charles is offline
post #5 of 7 (permalink) Old 03-03-2009, 10:31 PM Thread Starter
train wrecker
pusnboots's Avatar
i'm just going pull it all back off and not try to take the short cut.
overtightened for sure. it was the only one i didnt have to tighten.
it was the first day i ran it with no oil leaks.(different story,stupid o-rings) so i finally got on it and stayed on it. didnt look at the pressure though.
but when it let go, i was just cruising @45mph on a flat road. and that was after about 50miles of driving.
and my o-ring problem was on the oil rail, not on the pump fittings.
post #6 of 7 (permalink) Old 03-03-2009, 11:07 PM
I make smut cry
Whose dual pump kit are you running?
Cowboy Steve
Powerstroked162 is offline
post #7 of 7 (permalink) Old 03-03-2009, 11:58 PM Thread Starter
train wrecker
pusnboots's Avatar
Cowboy Steve
stealth.
but i bought it used.
