unplug your DP-Tuner... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 70 (permalink) Old 03-03-2009, 04:15 AM Thread Starter
PSDfan99's Avatar
..... and your radio stations come in clear for a change
So I've been living with "fuzzy" radio stations for a while (like a year), and today it occurred to me that maybe I should try something.... Reached under the dash, pulled the DP-Tuner off the PCM and the friggin radio comes in clear as day again
Apparently these F5 switches give off some kind of interference that fuks with the radio.
Looks like I need to relocate my F5 switch a little further away from the radio.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #2 of 70 (permalink) Old 03-03-2009, 04:24 AM
Ticking time bomb
Re: unplug your DP-Tuner...
wow are you serious.
groomzybanshe is offline
post #3 of 70 (permalink) Old 03-03-2009, 04:24 AM Thread Starter
PSDfan99's Avatar
dead serious
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #4 of 70 (permalink) Old 03-03-2009, 04:26 AM
Never Fry Bacon NAKED!
Stewart's Avatar
You do have the shielded cable, yes?
I have the shielded cable in my F250, but I'm still running with the unshielded cable in my Excursion, with only one incident that I know was caused by the cable being unshielded.
With my travel-trailer hooked up, and the brake controller in use, I hit my horn at some idiot who cut me off and it caused my to engine shut off.
Once I cycled the ignition off, everything reset and all was good.
Stewart
2002 F250 Lariat SC 4x2
- 38R, AC's, MBRP 4", AFE Big Boost, JW valve body, Riiffraff HPX soft line & CCV, ITP's OBA, Live Tuned by Jody
2000 4X4 Excursion
- John Wood 4R100, AFE Stage 2, MBRP 4", 1.0 housing, WW, F5, V and B code springs, ITP's OBA and pre-pump kit.
Stewart is offline
post #5 of 70 (permalink) Old 03-03-2009, 04:29 AM Thread Starter
PSDfan99's Avatar
I'm not sure if I have the shielded cable, the chip was brand new 1 year ago, so w/e Jody was using a year ago I have.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #6 of 70 (permalink) Old 03-03-2009, 04:36 AM
This is not happening in my truck, nor a chitload of other owners I know of. You may have another problem. Have you talked to Jody, or just decided to start a bashfest?
Tenn01PSD350 is offline
post #7 of 70 (permalink) Old 03-03-2009, 04:36 AM
PSD
CNDiesel's Avatar
Tin foil time?
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #8 of 70 (permalink) Old 03-03-2009, 04:41 AM
Sounds like a cable problem. My F5 with the flat cable caused radio interference as well, but with the shielded cable, it's fine.
Jake, give Jody a call.
TerminatorEngineering is offline
post #9 of 70 (permalink) Old 03-03-2009, 04:41 AM Thread Starter
PSDfan99's Avatar
Wait, seriously? Bash fest?
Find one post I have made BASHING anyone on this site EVER, never mind Jody. Talk about jumping to conclusions, DA.
The point of this thread was to "report" my findings. I was kind of shocked that the chip/switch actually did interfere with the radio reception.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #10 of 70 (permalink) Old 03-03-2009, 04:43 AM Thread Starter
PSDfan99's Avatar
I will, he needs to do some re-burns for me anyways so I'll talk with him next week when I send the chip in.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
