egt placement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-03-2009, 12:36 AM Thread Starter
brandon
bcangelo's Avatar
egt placement
I am about to install an egt gauge. I have been told to put it in the drivers side manifold. I am just worried about drillling into the manifold and getting all the shavings out so i don't destroy my turbo. What should i do? i don't want to take off the manifold
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #2 of 16 (permalink) Old 03-03-2009, 12:39 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: egt placement
Drill, tap, install and drive away.
Your drilling up, gravity makes things fall down. Myself, I have never seen anything fall up.
What shavings might get flung up there will blow by the turbo at idle with no issues.
Joe
CSIPSD is offline
post #3 of 16 (permalink) Old 03-03-2009, 12:40 AM
Joedog's Avatar
Re: egt placement
Just drill at a vertical angle, drill slowly, you will be fine.....just dont muck up the tap or break the bit Have fun
2000 F-250 Supercab/Shortbed 6-speed
Swamp Ass Hybrids, Swamp Ass tuning, Stage 1 Oil, 38R, Southbend Clutch.
Joedog is offline
post #4 of 16 (permalink) Old 03-03-2009, 12:48 AM
Banned
Re: egt placement
I have heard nuts and all kinds of sh*t fly right through the turbine at idle, no problem.
A few shavings is no problem. If you piled all the shavings that fell out back up in the manifold they would just blow right out the turbine wheel at idle, off idle without any notice.
Charles is offline
post #5 of 16 (permalink) Old 03-03-2009, 01:31 AM
Re: egt placement
Drill the hole slowly, use a sharp bit and don' t use excess force. Then put some grease on the tap it will catch almost all the metal.
It worked great on mine
01PSD is offline
post #6 of 16 (permalink) Old 03-03-2009, 03:36 AM Thread Starter
brandon
bcangelo's Avatar
Re: egt placement
thanks guys, i feel better about doing it
bcangelo is offline
post #7 of 16 (permalink) Old 03-03-2009, 03:50 PM
Busy Busy
Marty's Avatar
Re: egt placement
No reason for messy grease. Drill, tap, install, drive away.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 16 (permalink) Old 03-03-2009, 07:05 PM
<-- it's like that
Re: egt placement
Yep, I also drilled, tapped, and done. No grease, no vacuuming out shavings, nothing. So many PSD owners have done it this way, and no one has screwed up their turbo with metal shavings.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #9 of 16 (permalink) Old 03-08-2009, 11:45 PM Thread Starter
brandon
bcangelo's Avatar
Re: egt placement
installed my egt today. drilled, tapped, i did vacuum the shaving because i am always on the side of caution, and used a little magnet to ensure i did not leave any. everything works, thats for all of the tips guys
bcangelo is offline
post #10 of 16 (permalink) Old 03-09-2009, 04:25 PM
SD01WD's Avatar
Re: egt placement
Ok guys, I have a issue. I have a brother who rides the dark side in a
duracrap...He admires my Power stroke gage pod and wants one. I'll
have to install it so I need to know where to put the EGT probe. I know
most would say "where" but he is my older brother and has a few health
problems. Anyone know the best place on a duracrap?
Thanks in advance.
Bill
2001 SD 2 wheel drive
DP tuned by Scott @ TNT of CC
ITP Regulated Return/ in tank & prepump mods: When Only the BEST will do!
Tank has been harpooned
Gages: Boost and Pressure
on the post & 4" S/S turbo Back by Aljay.
Rancho's all around
SD01WD is offline
