Opinions on build? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 03-02-2009, 05:03 AM Thread Starter
Opinions on build?
Well basically my problem is how to do this in steps, more than just how to do it. I want to start building the PMR engine in my truck no then build a billit rod motor and toss all the bolt ons on it when I get it finished. My goal is roughly 600hp, and may not be my DD then but will be now. The only restriction on money is I cant take one step when I need to take another at the same time.
What cc injector and from who? This will probably not be done to my stock truck unless they can be tuned down. I like the idea of hybrids but am open to all options.
Turbo- Either a 38r for my truck now, then keep that in a twin set up for the build motor. Or an H2E unmodded now, then either s400 or modded h2e on the built motor.
Tuning- I am at a loss b/c I thought I was going to go with DP but I have heard a lot of talk lately that is not sitting well with me!
Big oil- for the number I am looking at, I'm thing stage 2 Stealth. Would I need a stage 3?
Trans- BTS is probably the first step in this whole process but my stock is working great now so I will wait till it seems shakey.
Fuel system- RR/bowl delete From ITP.
Built motor will have everything hopefully the new bed plate works out, studded, fire ringed, rods and rings, I want a good builder doin the work for piece of mind! Either Beans, Swamp, DI. This will also probably be who I have tune my truck!
Lets hear it!
TheDurtyDeez is offline
post #2 of 30 (permalink) Old 03-02-2009, 05:30 AM
Village Idiot
southmike's Avatar
Re: Opinions on build?
true 600 on fuel only will be tricky and need to be very custom tuned.
you can add the big oil, bcodes, or very large hybirds, twins etc..
but here is just a little parts needs that need to go in the new block
a girdle or swamps new milled beauty,billet rods, coated pistons, hi temp valves , hardened push rods, beehive springs , head studs, possibly fire rings, am ati or fluidamper, better intakes or re-enforce the stock ones by adding a collar,
fuel labs makes a new pump that looks to be ready for that kind of fuel flow.
southmike is offline
post #3 of 30 (permalink) Old 03-02-2009, 05:44 AM Thread Starter
Thanks, btw this truck wont be used to tow only DD, race perhaps, but it will be lifted and I will probably be running 40" +/- tires. All of that stuff I plan on throwing in the built motor, and I will be having one of the shops listed doing it.
Right now I am wondering how to go about things in my PMR motor, I hant performance now, with the ability to switch over to built motor without scapping and buying new, upgrade it and make big power. I am also not dead set on 600hp. Anything over 500+ I would be more than happy with!
post #4 of 30 (permalink) Old 03-02-2009, 12:40 PM
well your first thoughts were good get the BTS you wont have to change between motors. but on your PMR motor there have been guys who have rodded a motor with just the very basics so unless you have all the money to build the motor now I would just build the motor so you are not respending any money. Where are you located?
USAF TSGT Retired "Medically"
99.5 CCSB 4x4 built motor and BTS
99.5 EX Cab Long bed with mild mods and BTS
Big thanks to Swamps Diesel and BTS!!!
randylamarr is offline
post #5 of 30 (permalink) Old 03-02-2009, 02:46 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Call Swamps, Diesel Innovations, or Unlimited Diesel.
Make sure your tuning and injectors come from the same place. Are you willing to chance a 2500 dollar set of rods on someone other than those that built the injectors tuning?
Charlie is running a 38R in his compound setup as the small charger like you're talking, and he's made 638 if I recall correctly on fuel.
I wouldn't screw around with B-code injectors. Get hybrids, they're much more efficient and faster.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #6 of 30 (permalink) Old 03-02-2009, 04:17 PM Thread Starter
Erie, PA. I know the only things I was really thinking on this motor were big oil, and turbo, maybe even DIY stage 1's or something. But thats it I want to respend the least amout as possible, hopefully none!
post #7 of 30 (permalink) Old 03-02-2009, 04:33 PM Thread Starter
NOPE! If at all possible I want to get EVERYTHING from the same shop. Thats why I dont have a custom tuned chip now, as I want to figure out who I will be with in the end, then start buying from them.
Also who is Unlimited Diesel? I checked out their website and its still under construction. They are somewhat close actually, but I can get to ther builders in 10 hours and I'm ok with that.
post #8 of 30 (permalink) Old 03-02-2009, 05:02 PM
Smarty Power!
They're an up and coming but VERY knowledgeable shop in Bremen, Ohio...Nate and Ben build injectors, and are pretty much a full service shop.
The banner in my sig gives their phone number, and they're great guys to work with.
For what it's worth, they had a good bit to do with lukecline's engine build for his Super Duty, shooting for 800 on fuel...
Jarrett Matthew
post #9 of 30 (permalink) Old 03-02-2009, 05:08 PM
The Fireman
big_stroker's Avatar
Very good guys they have my truck right now.
Where you located?
big_stroker is offline
post #10 of 30 (permalink) Old 03-02-2009, 05:36 PM Thread Starter
Erie, PA, about 3 1/2 hours away from Unlimited, but also for as money as these parts costs, I am not basing my decision on travel time as long as its not in Cali or anything. I am interested in learning more about Unlimited though, especially after following Luke's build.
