Auto enginuity question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-01-2009, 03:51 AM Thread Starter
When running auto enginuity software. Does the calculated engine load function work for a 7.3 liter 2003 manual transmission.
hoptwoit is offline
post #2 of 6 (permalink) Old 03-01-2009, 02:19 PM
Smarty Power!
John_DeereGreen's Avatar
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Re: Auto enginuity question.
I'm not sure about the SD's, but I just went and tried it with the jurassic era PCM in my OBS and I didn't get anything...Dennis will probably be along before long to tell you though.
Jarrett Matthew
04.5 QCSB auto common rail
Smarty TnT; ISSPRO PERFORMAX
Suncoast full billet
John_DeereGreen is offline
post #3 of 6 (permalink) Old 03-01-2009, 02:27 PM
Village Idiot
LRTMatt's Avatar
As far as I know the net engine torque reading does not work on any 7.3 be it manual or auto.
LRTMatt is offline
post #4 of 6 (permalink) Old 03-01-2009, 11:05 PM Thread Starter
Thanks for the responses. Im trying to trouble shoot a problem and having a heck of a time. I have done just about everything I can think of but the engine still runs funny some days. One day it will run almost normal. The next it is puffing white (atomised but unburnt fuel). When it smokes the icp is too high and the mass fuel desired goes way up. The engine starts fine and idle it perfect. Im trying to figure out why some days it runs fine and other days it goes out to lunch. I have even had it do this within minutes. The only sensor I can find at the moment that is out to lunch is the engine coolant temp sensor the 2nd one (manual transmission). It reads as high a 300 F. I will change it but as far as I understand over 220 should cause a defuel.
Has anyone ever had this or seen it before.
There is another question I have. What kind of a throttle reading should I see with auto enginuity. I am seeing .55 volts off pedle and only 3.90 volts @ full throttle. Does the PCM have to calibrate for a new pedal ?
hoptwoit is offline
post #5 of 6 (permalink) Old 04-21-2009, 02:45 AM
throttle jockey by trade
hookin78's Avatar
I just bought AE, in the "User Guide" it explains how calculated engine load is calculated, it is calculated by comparing actual mass-air flow to max value of mass air flow. Unfortunatley 7.3 don't have a mass air flow sensor, therefore not being able to calculate this.
2000 F-350 six speed
2000 F-350 automatic (custom tree dent mod)
1978 F-350 4speed 460 pulling truck
hookin78 is offline
post #6 of 6 (permalink) Old 04-22-2009, 06:35 AM
Terminator Nation
Full throttle pedal voltage can be 4.00 to about 4.5 volts. Your 3.90 volts may be OK. You can slot the pedal mounting for the Throttle Position Sensor and rotate the sensor to bring up the voltage mechanically, there is no way to adjust the PCM.
old man dave is offline
