clamp on turbo/downpipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-28-2009, 08:21 PM Thread Starter
brandon
bcangelo's Avatar
Question clamp on turbo/downpipe
i just replaced my oem exhaust with a 4'' turbo back. i was told not to tighten the clamp on the turbo/exhaust to tight. how tight do i need to get it without messing something up. the nut never seem " to get harder to tighten" but i there was more thread on the bolt showing than before. any insight?
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
bcangelo is offline
post #2 of 4 (permalink) Old 03-01-2009, 12:28 AM
NorCalDiesel's Avatar
Re: clamp on turbo/downpipe
If you're installing for the first time you need to tighten the downpipe first before you tighten the remaining exhaust lengths. I get mine pretty tight. I bet it is about 20-30 ft/lbs. You don't want to strip the bolt. Once it is tight then proceed down the length of the exhaust sections and tighten back towards the rear.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #3 of 4 (permalink) Old 03-01-2009, 12:34 AM
Banned
And don't worry about the T-bolt. You will pull the threads out of the nut before you hurt the bolt. Then you'll just need to dig out another one. Or order another T-bolt clamp and steal the nut if you don't have them laying around.
Charles is offline
post #4 of 4 (permalink) Old 03-01-2009, 01:30 AM Thread Starter
brandon
bcangelo's Avatar
thanks guys.
bcangelo is offline
