WW install help!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-28-2009, 04:33 AM Thread Starter
WW install help!!
I am trying to switch out stock wheel for the wicked wheel, well I cant get the stock wheel off. I have the compressor side off and sitting there by the turbo in the truck NOT touching the WW with the wastegate still attached. I took the DP off and and tried jamming the wheel with a screwdriver wrapped with a towel, and still couldnt get it. What shoudl I do next to get the wheel off? Should I use a ratchet and put more torque to it?
Thanks guys!
TheDurtyDeez is offline
post #2 of 8 (permalink) Old 02-28-2009, 04:42 AM
NorCalDiesel's Avatar
Re: WW install help!!
I did mine that way a while back and it came off rather easily. You don't want to lean on that too hard if it is still in the truck. I used a ratchet, but keep it down to 3/8s and give it a try. The turbine is pretty strong iconel metal and will not bend, but you don't want to put too much force or pressure on the bushings.
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
NorCalDiesel is offline
post #3 of 8 (permalink) Old 02-28-2009, 04:45 AM Thread Starter
This might sound stupid but I DO want to go counter-clockwise to get it off right?
post #4 of 8 (permalink) Old 02-28-2009, 05:06 AM
Not stupid. IIRC Yes, counterclockwise. When you spin the WW on, get it hand tightened. The wheel will tighten itself while running once you start driving the trruck
post #5 of 8 (permalink) Old 02-28-2009, 07:27 AM Thread Starter
Got it! Thanks guys! Wierd thing though, when I test drove I had like no boost until it got completely warm. Then it was a beast like back to normal... Plus I think I fixed an exhaust leak, and that mother is loud! Should I be concerned with the no boost at first? It seemed like the EBPV was stuck open longer than normal.
post #6 of 8 (permalink) Old 02-28-2009, 11:46 AM
Lovin the Tuna
RedSmokey's Avatar
Correction for you, the EBPV stays closed not open, when you start the truck in the cold, and I believe the EBPV will stay closed until the truck warms up (thats its purpose). I could be wrong, but from what i have read on here a while back i believe thats how it works. And for the no boost till its warm, i cant really help you, where about do you live and whats the weather/tempature like? When i first start my truck up and its cold for me, the truck is a slug and turbo lag is a while longer... Hope that helps a little
2001 F250
2000 F250
RedSmokey is offline
post #7 of 8 (permalink) Old 02-28-2009, 02:29 PM Thread Starter
Yes, sorry it was closed. Wierd thing is I started it in a 75* garage, that I pulled in a few hours earlier after running at operating temp, and pulled it out in like 10* temps. Could this cause the EBPV to close?
post #8 of 8 (permalink) Old 02-28-2009, 03:40 PM
Village Idiot
southmike's Avatar
it might ..give it a few tries under different circumstances and see what happens.
like runnning on a warm engine.
southmike is offline
