Hypermax Hyper Flash - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-26-2009, 10:56 PM Thread Starter
blue99sd's Avatar
Has anyone used or have this? If so how well does it work? Also If you have it can you add a TS to it or will it work? Just curious.
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #2 of 8 (permalink) Old 02-26-2009, 11:24 PM
PHPDiesel's Avatar
Re: Hypermax Hyper Flash
Can we get a sticky?
To answer your questions.
1. Don't know, never used it.
2. If it is a programmer, no it will not work with the TS chip. The chip will override any programming on the PCM.
Cody
PHPDiesel is offline
post #3 of 8 (permalink) Old 02-26-2009, 11:42 PM Thread Starter
blue99sd's Avatar
Its suposed to take your stock ecm from sock hp to 300 to 330 hp. it accually reflashes your ecm.
99 PSD dually
4" lift 35' tire
K&n air filter
cc mod
Beans D66 turbo
blue99sd is offline
post #4 of 8 (permalink) Old 02-26-2009, 11:55 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
IE its a programer... and will not stack with a chip. The only thing that will stack with a chip is a ICP mod.
Joe
CSIPSD is offline
post #5 of 8 (permalink) Old 02-27-2009, 12:44 AM
i have one it works fine, slow as hell
has good power, hypermax tuning is pretty good, i had it stacked w/ a banks 6 gun have since sold the 6 gun
also i'm running dp tuner now wanted something the switched on the fly
early 99 F350 6sp 4X4 4"dp, 5" stacks, dp tuner 60tow, 80 tow, 80 econo, 120race, 140 smoke, smoke lope, turbonetics bb, BD exhaust brake, south bend 550hp
Justblowin'smoke is offline
post #6 of 8 (permalink) Old 02-27-2009, 12:58 AM
CSIPSD's Avatar
IE a ICP mod...
Joe
CSIPSD is offline
post #7 of 8 (permalink) Old 02-27-2009, 02:08 AM Thread Starter
blue99sd's Avatar
So its not worth it with the mods i have?
99 PSD dually
4" lift 35' tire
K&n air filter
cc mod
Beans D66 turbo
blue99sd is offline
post #8 of 8 (permalink) Old 02-27-2009, 02:20 AM
greenbeast's Avatar
In a word...no. Proper tuning is what you need!
greenbeast is offline
