Intercooler Pipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-26-2009, 02:51 PM Thread Starter
1999SuperDutyStroke's Avatar
Send a message via Yahoo to 1999SuperDutyStroke
Intercooler Pipe
I took the plunge and went with the Foil delete. Well after i got it off i found that at some point in the past the pipe had gotten over against the Power Steering pulley and now i have a small hole. Is it worthy of trying to fix or should i just buy a new IC pipe. Does anyone have one just laying around they dont need and want to get rid of. And how do you get that nasty glue off the pipe?
Ray
E.T.A.P.S. Member
Late1999~F250 SuperDuty~Shortbed SCab~XLT~315 Hankook 10Rs~6" Mitre Cut Stacks~DIY Intake~DP Tuner~Transgo Tugger~Foil Delete~IssPro Gauges~
1999SuperDutyStroke is offline
post #2 of 8 (permalink) Old 02-26-2009, 02:59 PM
DieselPower1966's Avatar
Send a message via MSN to DieselPower1966
Re: Intercooler Pipe
Ray,
as for the hole I'm not sure,
as for the glue, I found the easiest way to get it off
was soak it with wd40 and use a scouring pad to remove the glue.
I'm guessing you're going to paint them, make sure you use hi-temp paint
good luck
DieselPower1966
John
DieselPower1966 is offline
post #3 of 8 (permalink) Old 02-26-2009, 03:02 PM Thread Starter
Planning on powdercoating
Ray
E.T.A.P.S. Member
post #4 of 8 (permalink) Old 02-26-2009, 03:15 PM
theSLEEPER's Avatar
I got one for 8 bucks at a junkyard...
theSLEEPER is offline
post #5 of 8 (permalink) Old 02-26-2009, 04:46 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Just weld it up and away ya go. With a hole in it you were loosing boost pressure so you should see a boost in performance.
Joe
CSIPSD is offline
post #6 of 8 (permalink) Old 02-26-2009, 04:54 PM
theSLEEPER's Avatar
So it's kinda like an upgrade!
post #7 of 8 (permalink) Old 02-26-2009, 04:57 PM
CSIPSD's Avatar
Joe
CSIPSD is offline
post #8 of 8 (permalink) Old 02-26-2009, 05:01 PM
All done now
Arisley's Avatar
Fixing the hole will be. Upgrade to stock.
Arisley is offline
