New Intake - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 02-26-2009, 01:08 AM Thread Starter
tbolt's Avatar
New Intake
I just installed the AIS from Ford. It was simple. I have an early 99 and the original looked like the only thing worse would be a bucket and a garden hose. What is the opinion on the AIS? My truck is stock with a programmer and only used to tow my 37' toyhauler. Is it worth the $$$? I have an acct at the local Ford dealer so did not pay full retail. Thanks for any opinions.
Glen
tbolt is offline
post #2 of 20 (permalink) Old 02-26-2009, 06:08 PM
Re: New Intake
Glen
Excellent option for you. Probably what I will do too.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #3 of 20 (permalink) Old 02-27-2009, 01:05 AM Thread Starter
tbolt's Avatar
Smile Re: New Intake
Thanks
tbolt is offline
post #4 of 20 (permalink) Old 02-27-2009, 03:02 PM
Village Idiot
southmike's Avatar
Re: New Intake
lol bucket and hose ...
did you get the 20$ fender sleeve
southmike is offline
post #5 of 20 (permalink) Old 02-27-2009, 07:27 PM Thread Starter
tbolt's Avatar
Re: New Intake
Don't know about a $20 sleeve.
tbolt is offline
post #6 of 20 (permalink) Old 02-27-2009, 11:55 PM
Village Idiot
southmike's Avatar
Re: New Intake
it is the lil fender sleeve on the side for early 99's i believe.
I am not sure that it amounts to more then a beer cozy with no bottom from what i recall seeing.
that is why the early 99's are an eek more.
i don't think it makes much of a diff.
post #7 of 20 (permalink) Old 02-28-2009, 03:02 AM Thread Starter
tbolt's Avatar
Re: New Intake
The kit I bought has a tube that goes to the core support beside the IC and came with a heat shield for the bat. And a new bat tray to turn it slightly. Should I plug the opening in the fender where the orig intake went??
Glen
tbolt is offline
post #8 of 20 (permalink) Old 02-28-2009, 03:47 PM
Village Idiot
southmike's Avatar
Re: New Intake
i wouldn't ,
if anything you would want to use it .
for now i wouldn't mess with it, just drive and enjoy some safe air filtering.
the tube that goes to the core support beside the IC sounds like the zoodad mod, a bunch of people do that one , more direct air. but maybe someone more ais informed will chime in .
post #9 of 20 (permalink) Old 02-28-2009, 04:19 PM
Re: New Intake
I like my AIS setup. I'm not sure how it will do with the new turbo when I get it in (GT38R) as even with a brand new filter I can suck the filter minder or whatever it's called, just shy of the red "change filter" line with stock injectors and turbo. (It will get close to 30psi though) Filter seems to last a LONG time. Instructions said to use the filter minder not judge it by how it looked and mine has been in for 1.5 years and still hasn't moved the filter minder any farther and I do go off road. Hope yours works out as good for you!
-Aaron
GreenF350 is offline
post #10 of 20 (permalink) Old 03-02-2009, 02:02 AM Thread Starter
tbolt's Avatar
Re: New Intake
thanks, I saw a video on here somewhere that showed the stock rubber tube being collapsed while revving. You might want to check that if you make any more boost.
Glen
tbolt is offline
