downpipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-25-2009, 04:58 PM Thread Starter
downpipe
i have a 1997 f 250 powerstroke and i have talked to a few people about putting in a new exhaust system on and they have said that if i upgrade to a 3 inch downpipe it will rattle and i will have trouble fitting it in
powerstroked97 is offline
post #2 of 7 (permalink) Old 02-25-2009, 05:30 PM
secondarychaos's Avatar
Re: downpipe
Not if you put it in right, and if you're going to do an exhaust, the downpipe will be very helpful with EGT's and turbo spool.
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 7 (permalink) Old 02-25-2009, 05:34 PM
Re: downpipe
If you look at where the downpipe passes the firewall you will see that it pinches down alot. To fit a 3inch downpipe you have to bend the seam on the firewall back (sounds worse then actually doing it). If it rattles take downpipe out and bend some more, some trucks have more room between engine and firewall then others but its a case by case basis, all have to bend that seam, only question is how much. For more info look in the obs forum rather then the superdutys.
ltldemonz is offline
post #4 of 7 (permalink) Old 02-25-2009, 07:21 PM
Built By Me
444smoker's Avatar
Re: downpipe
make it easy on yourself and get a porta power and stick it up in there and bend the pinch welded seem up real good throughout that area and you shouldn't have any vibrations, they are really not that bad with the porta power 30min and you should have it in and done.
Robert
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
444smoker is offline
post #5 of 7 (permalink) Old 02-25-2009, 09:59 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
Re: downpipe
i may just be lucky but i did not have to bend the lip on mine. i used a flowmaster dp. now to clear the 4"... ya big hammer.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #6 of 7 (permalink) Old 02-25-2009, 11:02 PM
<-•DEISEL CRAFT•
coalroller3x's Avatar
Re: downpipe
i installed a 4inch down pipe on my 99 7.3l and i have no more turbo lag.
my buddy has a 97 ps and we stcked it but not yet changed down pipe.
that looks like a nightmare.
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
coalroller3x is offline
post #7 of 7 (permalink) Old 02-26-2009, 12:33 AM Thread Starter
Re: downpipe
thanks for your help
