Any comments on what to do next? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 02-24-2009, 03:14 AM Thread Starter
Ramond is a ritard
stutterinwithastack's Avatar
I have a 2000 F-250 with, DP-F5 chip, beefed up trans, 6673 air filter, EBPV delete, foil delete, high presser oil cross over, edge evo for gauges, intake air heater delete, straight pipe with 6 inch stack. I pull trailers and just a daily driver. What can I do next on a low budget?
stutterinwithastack is offline
post #2 of 24 (permalink) Old 02-24-2009, 03:47 AM
Ticking time bomb
Re: Any comments on what to do next?
how low of a budget maybe a 38r turbo??? is your 2000 early or late
groomzybanshe is offline
post #3 of 24 (permalink) Old 02-24-2009, 04:31 AM
<---Beer version of PMR's
Seven3Leeter's Avatar
right now you are up against 4 bottlenecks:
High pressure oil volume
Injector fuel delivery
Air delivery
Egt limitations
From here on out mods get expensive. If you are looking for moderate hp upgrade a hpop will grant a noticable seat of the pants improvement. If you're looking to get more wild; hybrids and a turbo. If you get too much wilder you will be needing headstuds and a fuel sys. On a real tight budget I'd look at the new adrenalin Hpop(not sure what the wait time to get one is). For econo turbo I'd look at a van turbo or adding a larger turbine housing on yours, best
way to go though, is saving for a 38R, Imho.
Tuning by Sniper
Transmishing by John Wood
Breathing by AFE
Exhausting by Pinncle
Monitoring by me and Isspro
Compressing by Wicked Wheel
Wasting by Turbomaster
Stopping by Powerslot
Lifting by Donahoe
Rolling by Toyo
Protecting by Ranch Hand, God, and Ruger
Addiction by
[SIGPIC][/SIGPIC]
by Garrett, Alliant, ITP, DP-Tuner
Seven3Leeter is offline
post #4 of 24 (permalink) Old 02-24-2009, 06:20 PM
<-- GO BRONCOS
dblamp's Avatar
ITP regulated return http://www.itpdiesel.com/store.php/p...ted_Return_Kit
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #5 of 24 (permalink) Old 02-24-2009, 07:09 PM
Layson's Avatar
What are you horsepower goals? and what is the budget??
Layson is offline
post #6 of 24 (permalink) Old 02-25-2009, 02:24 AM Thread Starter
Ramond is a ritard
late couple hundred or so
post #7 of 24 (permalink) Old 02-25-2009, 02:33 AM Thread Starter
Ramond is a ritard
i want as much as i can but still be reliable
post #8 of 24 (permalink) Old 02-25-2009, 02:37 AM
War Pig
Caballo Diablo's Avatar
In tank/pre-pump mod, Overboost Innihilator, or maybe a van turbo.
Chad
04 F350, CC, LB, 4X4 Fat Bottom Girl....Butt A$$ Stock
SOLD>>>'00 F250, DP-Tuner, 5" Straight Pipe, S&B intake, autometer, Racer X TC and VB, Full Force Stage 1, prepump/in-tank mod, Annihilator, 203*
ET: 5.024 250' Mud Track
Caballo Diablo is offline
post #9 of 24 (permalink) Old 02-25-2009, 05:08 AM
Village Idiot
southmike's Avatar
powerslot brakes and hawk pads...add a wicked wheel if you ever get surge ..
have a look at dieselsite.com for other low cost goodies.
( and some not so low cost.)
southmike is offline
post #10 of 24 (permalink) Old 02-25-2009, 04:16 PM
Layson's Avatar
I would watch for a slightly used GTP38R and then some used sticks after that....
Layson is offline
