Rebuild Kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-23-2009, 08:09 PM Thread Starter
Busy Busy
Marty's Avatar
Rebuild Kit
For Factory L/S - what all do I need?
I'm being asked if it's a 2 or 3 pinion set and I think it's a 3....
Any help/part number's???
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #2 of 6 (permalink) Old 02-23-2009, 08:28 PM
Plays with Motors
Machinist's Avatar
Re: Rebuild Kit
You need to pull the diff cover and see which posi unit you have - the 3 pinion is a split case and the 2 pinion is a single case.
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #3 of 6 (permalink) Old 02-23-2009, 08:39 PM
Hater Club
Dirk's Avatar
Re: Rebuild Kit
I thought the 2 pinion was from the 10.25 and the 3 pinion was the 10.5?
Porch Monkey. It's cool, I'm taking it back.
Dirk is offline
post #4 of 6 (permalink) Old 02-23-2009, 09:55 PM
theSLEEPER's Avatar
Re: Rebuild Kit
Subscribing... I'm VERY interested! Is there a way to tighten up the factory LS so it's harder to make it slip?
theSLEEPER is offline
post #5 of 6 (permalink) Old 02-23-2009, 10:12 PM Thread Starter
Busy Busy
Marty's Avatar
Re: Rebuild Kit
Bump
Elkton, Maryland
Marty is offline
post #6 of 6 (permalink) Old 02-23-2009, 10:49 PM
Plays with Motors
Machinist's Avatar
Re: Rebuild Kit
I'm answering similar questions in this other thread too -
https://powerstrokenation.com/forums/...ad.php?t=24802
Yes, you can tighten up the factory posi and it works quite well after that. I built my 3 pinion unit with correctly ordered clutch/plates and shimmed it up quite a bit, then used less friction modifier than recommended.
2011 335i M-Sport
