Belt driven HP water injection pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-23-2009, 04:43 AM Thread Starter
What else?
smokyred's Avatar
Anybody ever tried running a high pressure pump off of a belt drive for a water injection system?
Reason I ask is I don't have my A/C anymore, and if I could put a belt driven high pressure pump in it's place on the belt I would much rather do that than run a low pressure electric pump.
I figure if I'm going to run water injection, I may as well make it at least 500psi. Any ideas on pumps? I've looked around but I'm not really sure what I should be looking for or how I would set it up?
Dave
smokyred is offline
post #2 of 17 (permalink) Old 02-23-2009, 05:05 AM
Sponsor
Re: Belt driven HP water injection pump
You're also going to need a Simpson Valve, 1" supply line and at least 3/4" return line... Have Fun!
UNLIMITED_DIESEL is offline
post #3 of 17 (permalink) Old 02-24-2009, 05:23 AM Thread Starter
What else?
smokyred's Avatar
Could you be a little more specific? I'm completely clueless about mechanical water injection.
Thanks,
Dave
smokyred is offline
post #4 of 17 (permalink) Old 02-24-2009, 05:25 AM
DarkShadowDiesel's Avatar
Pic from Haisley's site - maybe this will help a bit
It looks to me like you need a large supply line, goes to a tee w/ bypass valve & water return. Then water control valve, with another return, also boost reference line, and feed to the manifold for separate lines. That system is $2422.. I can't find anything on simpson valves I think they are hard to find? Unlimited?
2002 F250
DarkShadowDiesel is offline
post #5 of 17 (permalink) Old 02-24-2009, 05:33 AM Thread Starter
What else?
smokyred's Avatar
Aha, that desn't seem nearly as complicated, now to source the parts to know the cost. And to find those sources.....
Dave
smokyred is offline
post #6 of 17 (permalink) Old 02-24-2009, 05:48 AM
MidTennPSD's Avatar
Originally Posted by UNLIMITED_DIESEL View Post
Simply Magical. Nice Work. Large frame S400 atmosphere?
MidTennPSD is offline
post #7 of 17 (permalink) Old 02-24-2009, 06:52 AM
2Cruel
moremph's Avatar
simpson valves arent cheap around 700 i believe
Travis
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
moremph is offline
post #8 of 17 (permalink) Old 02-24-2009, 01:18 PM
Sponsor
THANKS!
They are both S475's...With different housings
Dave have fun with the Simpson valve. Sometimes you can source them used, but like Travis said, they are about 700-800 brand new.
post #9 of 17 (permalink) Old 02-24-2009, 06:53 PM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Travis
Unloader valves are around $40 to $80 for upto 3000psi
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #10 of 17 (permalink) Old 02-24-2009, 07:43 PM
Sponsor
Explain... PLEASE
