WOT "pinging"? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 87 (permalink) Old 02-23-2009, 03:06 AM Thread Starter
PSDfan99's Avatar
WOT "pinging"?
So when I run my truck in the highest setting on my DP-Tuner which is 120 race I get this detonation/ pinging noise at WOT. If I back out if the throttle a little bit it goes away and it feels like I gain power when I back out if it. When it's at WOT and "pinging" it seems a little down on power compared to when I let out of it a little bit.
My lower settings on the DP don't do this "pinging", only the 120R. Also, I never noticed that the truck did this before I installed the modded 17* HPOP. When I had the stock 15* I don't think it did this. Another thing to mention, about 2 years ago when I first got a plain-jane TS 6-pos chip I would get the same "pinging" when I would go WOT on the highest program.
The DP-Tuner was tuned for a stock 15* pump, now I have the modded 17*, could it be a simple tuning issues that needs to be adjusted for the bigger HPOP?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #2 of 87 (permalink) Old 02-23-2009, 03:15 AM
Village Idiot
southmike's Avatar
Re: WOT "pinging"?
I don't get any pingng on my ts chip...
what kind of pinging ..
rev limiter defuel... turbo wheel contact , not sure what valve float sounds like.
southmike is offline
post #3 of 87 (permalink) Old 02-23-2009, 03:24 AM Thread Starter
PSDfan99's Avatar
Re: WOT "pinging"?
The noise is like pre-detonation or something. Like when a gas engine pings from fuel or whatever, kind of sounds like that. It's not a mechanical noise like metal on metal, it's a noise that seems to be from the way the fuel is being delivered or something. It only does it in the 120R at WOT, so I maybe the fuel delivery @ WOT in that program is causing it. I just need to call Jody I guess.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #4 of 87 (permalink) Old 02-23-2009, 04:08 AM
Re: WOT "pinging"?
It could be your 17 degree pump if it made that much of an improvement in pressure and you were tuned on the ragged edge before...... You could just have one of those trucks with a little bit advanced timing from the factory.
mattr66 is offline
post #5 of 87 (permalink) Old 02-23-2009, 04:21 AM Thread Starter
PSDfan99's Avatar
Re: WOT "pinging"?
Is the noise I'm hearing timing? The truck definitely loses power when it starts to pinging or whatever you want to call it.
And yes, over my factory 15, the modded 17* was a huge improvement on the top end, my truck used to fall on its face, now it rips pretty hard.
Early 99 F-350
SOLD
New truck:
PSDfan99 is offline
post #6 of 87 (permalink) Old 02-23-2009, 04:48 AM
What else?
smokyred's Avatar
Re: WOT "pinging"?
If it's loosing power when it's pinging, I would stay out of that program until you get this issue fixed, it can't be good.
Dave
smokyred is offline
post #7 of 87 (permalink) Old 02-23-2009, 05:33 AM
Body Type: MULE
CATdiezel's Avatar
Re: WOT "pinging"?
what do you have for a fuel system,
no fuel pressure will make the very pinging yo uspeak of when the injectors are starved for fuel and trying to fire.
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
CATdiezel is offline
post #8 of 87 (permalink) Old 02-23-2009, 12:07 PM
SeeYa's Avatar
Re: WOT "pinging"?
Which pump do you have?
Cat actually summed it up with what he posted. Fuel systems (even on a stock truck) make it feel stronger and deliver the fuel so much better. I noticed many things in the way of how my EX ran after installing ITP's fuel system. With bigger injectors it's a must or you will be starving the injectors. As for the pump, Jody will need to know what modded pump you have to be able to tell you if you need new tunes.
Diane
SeeYa is offline
post #9 of 87 (permalink) Old 02-23-2009, 01:30 PM
Banned
Re: WOT "pinging"?
I had written a post about this, but deleted it.
Instead, I"ll just ask why does everyone feel the need to actually pretend they don't know exactly what is happening at WOT with this truck in this program?
I don't expect an "answer" to that, nor do I want to read one. Wake up people!
Consider an oscilloscope your "Diet Pepsi Max".
So true.
Charles is offline
post #10 of 87 (permalink) Old 02-23-2009, 01:48 PM
SeeYa's Avatar
Re: WOT "pinging"?
With out talking to him and him datalogging in the moment this happening we can sit here all day posting what we "think" it is. Heck he could have gotten some bad fuel somewhere for all we know. It could be one of a ton variables.
If you want an opinion he has probably advanced the timing to a "degree" by installing the pump and now he is hearing the noise as the result. Without hooking up equipment and monitoring we'll never know that for sure.
To be stating a fact, with Stg. 2's he is starving the injectors for fuel and he needs to get the fuel system he has in his signature as one of his next mods he is going to do.
This is suppose to be a helping Forum not a "I have nothing useful to post so I'll just put someone down" Forum. <kiss>
SeeYa is offline
