1400 EGT in headwind on DP 120, is temp normal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-21-2009, 11:34 PM Thread Starter
Hi,
Today I was testing a downshift issue while in DP 120 on I-70 in central IL and the headwind was BAD! I stomped on the go pedal while cruising at 65 MPH and truck started to launch forward quickly. I noticed my EGT gauge jump to 1400 and the engine outline lit up in lower left corner of instrument cluster. I got off the pedal very fast. EGT's dropped to 1000 then down to 800 rather quickly, and light went off approximately 1 minute later. Is this normal for the situation I was in?
Thanks, V/r Les
USAF CCM is offline
post #2 of 9 (permalink) Old 02-21-2009, 11:42 PM
Canadian Stroker
doubledoor's Avatar
Re: 1400 EGT in headwind on DP 120, is temp normal?
Do you have a boost fooler? Sounds like to much boost. Mine does it if I hit
28psi of boost. Then goes out in about a minute.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #3 of 9 (permalink) Old 02-22-2009, 02:28 AM
1400 is OK for a short burst but yoou would not want to run it there all the time
Diesel Tech is offline
post #4 of 9 (permalink) Old 02-22-2009, 03:55 AM
got fuel?
goodstktbo's Avatar
wheres the probe at??
97 250/95 motor, 400/300's, ts, swamps tuning,gen3, s475, Intercooled, h11 studs,a1000, built tranny. 3.55's, 237,xxx miles fastest non reg. cab obs [email protected] fuel
94 explorer. dd
goodstktbo is offline
post #5 of 9 (permalink) Old 02-22-2009, 04:05 AM Thread Starter
Thanks.
OOPS! Good Point! I'm a pre-turbo believer. V/r Les
USAF CCM is offline
post #6 of 9 (permalink) Old 02-22-2009, 05:18 AM
Binder man's Avatar
I can't get over 1200 in any of my tunes no matter what I'm doing. I'm sure I could in extreme pulling a trailer, but empty there is no way. My boost gauge goes straight to 31 and pyro to 1200 and she'll sit there.
Early 99, regular cab, Six Speed, Wildman Tuned, Red wastegate line MIA, muffler MIA, Isspro EGT/Boost, DIY Tymar, EBPV Switch, a slipping South Bend, 2.5" leveling kit, 35x12.5 BFG All-Terrains, 16.5" American Racing wheels SOLD
04, red regular cab, six speed, Edge SOLD
97, silver regular cab 300/200 s300
Binder man is offline
post #7 of 9 (permalink) Old 02-22-2009, 06:40 AM
1400 seems a little high. With the 120 program on my truck, I usually stay below 1,000 unless I am going up an incline while in overdrive at a lower RPM. In this case, the engine is being lugged a bit and my EGTs will hit 1250 give or take.
01 7.3L 152K miles - Alliant AC injectors, ITP regulated return, AIS, bellowed up-pipes, DP tuning, JW trans, DC Power 185A Alternator
darkstar is offline
post #8 of 9 (permalink) Old 02-23-2009, 06:24 AM
Midwestern4x4.com
lrazer's Avatar
i hit 1303 the other night the doing about 120 on the 120 tune
03 Intl 4300 Dt466
16 F350 RC 4x4
10 Intl Durastar Dt466
15 F350 RC DRW 4x4
14 F550 CC 4x4
02 F250 CCSB 4x4 ZF6 Swap
-P.I.S. 160cc/30%, GTP38R, T500
-Regulated Return, DP Tuned
99 F550 RC 2x4 ZF6
01 F250 SCLB 4x4
-DIY Intake, 4" Exhaust
02 F250 SCSB 4x4
-AIS Intake, 4" Exhaust, DP Tuned
lrazer is offline
post #9 of 9 (permalink) Old 02-23-2009, 06:25 PM
secondarychaos's Avatar
What year truck?
Do you have gauges?
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
