where does the tranny temp sender unit go? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-21-2009, 10:48 PM Thread Starter
jaybuller's Avatar
i got these gauges and am now installing them well got the exaust temp and the boost going now for the tranny temp guage, my instructions dont tell me where it goes or anything. the sender the guage came with looks like a O2 sensor in a way. it screwws into a hole somewhere. now where is the hole it goes into?
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
post #2 of 6 (permalink) Old 02-21-2009, 11:10 PM
<-- GO BRONCOS
dblamp's Avatar
Re: where does the tranny temp sender unit go?
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5
(No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
dblamp is offline
post #3 of 6 (permalink) Old 02-22-2009, 12:16 AM Thread Starter
jaybuller's Avatar
thanks thats exactly what i needed.
post #4 of 6 (permalink) Old 02-23-2009, 01:57 AM
Fro_911's Avatar
With your auto tranny check to see if your temp gauge is a single wire or dual wire sensor. If it's the single wire (short sweep) then you'll be fine with the sending unit supplied. If it's a dual wire (full sweep) gauge, then the sending unit is too long and will bottom out in the transmission. You'll need to buy a 1/8" male to 1/8" female extension to space the sending unit out. I just finished changing my gauges out to some autometer cobalts and had this same issue... the extension is about $2, the only thing I had to do in addition was drill the extension out a small amount so the sending unit probe would fit.
Fro_911 is offline
post #5 of 6 (permalink) Old 02-23-2009, 05:01 AM
<-- GO BRONCOS
dblamp's Avatar
I have the full sweep Isspro trany gauge, and it fit just fine, no problems.
Anthony
dblamp is offline
post #6 of 6 (permalink) Old 02-23-2009, 12:23 PM Thread Starter
jaybuller's Avatar
I put mine in yesterday it did feel like it hit the back when it got tight but it all works fine no leaks and the tranny runs fine drove it around yesterday and the tranny temp never got over 140. btw mine was the 2 wire one.
