Damper problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 02-21-2009, 10:33 PM Thread Starter
SKWERL's Avatar
Damper problem
When taking off my stock damper to put on the fluidampr, the puller stud snapped and now its stuck in the end of the crank. Ive been cranking on this thing for a while and it doesnt look like the damper has moved at all. Yes I removed the damper bolt. I cant figure out why its not coming off. Im lost on this one I could use any help at all.
Thanks
Earl
SKWERL is offline
post #2 of 39 (permalink) Old 02-22-2009, 01:00 AM
Layson's Avatar
Re: Damper problem
That sucks! Is the stud still stuck in there? Did you go buy a new puller? It should come right out?
Layson is offline
post #3 of 39 (permalink) Old 02-22-2009, 02:05 AM
I make smut cry
Re: Damper problem
I never had that problem..... weird. What brand of pulley puller were you using?
Cowboy Steve
Powerstroked162 is offline
post #4 of 39 (permalink) Old 02-22-2009, 02:08 AM
Busy Busy
Marty's Avatar
Re: Damper problem
Why didn't you have the dampner bolt still on when using the puller?
I did two of them today and if you take the bolt out and the washer off and put the bolt back in you can use the puller against that.
Found my leak today while doing it as well...
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #5 of 39 (permalink) Old 02-22-2009, 03:18 AM
Powerstroke Racer's Avatar
Re: Damper problem
you did take the washer off?
Powerstroke Racer is offline
post #6 of 39 (permalink) Old 02-22-2009, 04:13 AM
Plays with Motors
Machinist's Avatar
Re: Damper problem
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #7 of 39 (permalink) Old 02-22-2009, 04:14 AM
Re: Damper problem
Originally Posted by Machinist View Post
been there done that
post #8 of 39 (permalink) Old 02-22-2009, 04:46 AM Thread Starter
SKWERL's Avatar
Re: Damper problem
So what happened was the end of the stud on the puller went through the threads for the damper bolt. How I dont know. yes the washer was off and the puller was new.
Well it looks like its time for a new crank and bottom end build. To bad this is my only ride.
SKWERL is offline
post #9 of 39 (permalink) Old 02-22-2009, 04:47 AM
Starting Over
kainers's Avatar
Re: Damper problem
how far did it go in?
kainers is offline
post #10 of 39 (permalink) Old 02-22-2009, 04:52 AM
Built By Me
444smoker's Avatar
Re: Damper problem
can you not run a tap down it and clean it up or is it to ugly to do that?
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
444smoker is offline
