Do I really need the EBPV tube? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-20-2009, 08:05 PM Thread Starter
Keyboard Thug
Big Bore's Avatar
I have had an exhaust leak I couldn't track down, well, I found it with a little help from the exhaust brake that was forcing air to come out that tube and helped me locate the break. The EBPV tube sheared in half as if cut with a tubing cutter. On my OBS that has a non EBPV pedestal I put a code fooler of some kind. My SD does not have an EBPV either, think it was lost when the 38r was installed. Anyway, what problems will I encounter if any if I just put a plug in the head? It has not caused an SES light with it being completely disconnected. I have not run a scan for codes yet. I'm on my way to the hardware store and I'm planning to just pick up a plug and be done with it. If needed I'll get a new tube, but right now I'd like to get rid of that leak.
99 F250 4x4 SC SB Eats 6.0's
Originally Posted by !!!PainTrain!!! View Post
I'm not saying the 7.3 is god's gift to diesel either. But atleast when a CPS goes out you can change it on the side of the road. I don't know about you but I'm running out of places in my glove box to store injectors, head studs, new heads, up pipes, fuel pumps, ficms, and a lift to remove the cab.
Big Bore is offline
post #2 of 7 (permalink) Old 02-20-2009, 09:02 PM
fbilly420's Avatar
Re: Do I really need the EBPV tube?
Are you talking about the Exhaust back pressure sensor tube on the pass side exhaust manifold?
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 7 (permalink) Old 02-20-2009, 09:47 PM
<-- it's like that
Frank, I have the tube plugged and the sensor is zip tied next to the HPOP. Having the EBP sensor read ambient pressure forever hasn't affected power or mileage on my truck. I've hooked it back up once before, and couldn't tell a difference. If I completely remove the sensor from the wiring, then I get a CEL, so for now the sensor stays connected to the wiring harness, but it's not mounted in the tube.
So yeah, feel free to plug the tube since you no longer have an EBPV anyway.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #4 of 7 (permalink) Old 02-21-2009, 12:46 AM Thread Starter
Keyboard Thug
Big Bore's Avatar
Problem solved with a 5/16 flare cap. Noticed slightly less lag on the bottom, and a little quicker spool up.
Big Bore is offline
post #5 of 7 (permalink) Old 02-21-2009, 12:47 AM Thread Starter
Keyboard Thug
Big Bore's Avatar
Yes.
Big Bore is offline
post #6 of 7 (permalink) Old 02-21-2009, 01:25 AM
Martin #6's Avatar
Frank,
Did you notice any changes with the egt's after removing the tube and plugging the hole?
2008 F-250 Lariat CC 4x4. EPA stock.
Martin #6 is offline
post #7 of 7 (permalink) Old 02-21-2009, 02:10 AM Thread Starter
Keyboard Thug
Big Bore's Avatar
Originally Posted by Martin #6 View Post
Frank,
Truthfully I was in a big hurry to get the shower drain fixed, which is why I made the 120mi round trip today, and never looked at any of the gauges. I'm heading out to my other house now and will be crossing a pass, so I'll pay attention. New DP tunes are inbound also with some of the fuel backed off for my injectors, which may help I'm thinking.
Big Bore is offline
