boost gauge install question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-20-2009, 01:30 AM Thread Starter
silverpsd_06's Avatar
how did u guys run the boost line up to the actual gauage guy that owned the truck before put alot of kinks in the line and now is not reading anything any ideas would be appreciated and what did u hook the line to? the map or did u drill and tap a fitting into the turbo housing right before it connects to the intercooler piping
2000 f-350 SRW CC, 6" lift 22" KMC wrapped in 37" Toyo's, S465, Swamps 275/226, Studs, Springs, Pushrods, Gen3, TS 6 pos chip with Swamps Tunes...
silverpsd_06 is offline
post #2 of 2 (permalink) Old 02-20-2009, 02:15 AM
Re: boost gauge install question
If you have an auto transmission there is a large plug where the clutch hydralic line would go through the firewall. If you have a manual there is a small plug on the firewall just to the right of the turbo as you look at it. Those are where I have run lines before.
I have connected to the AIH port and to the MAP line. Both work but it is nice to get rid of the AIH as it is restrictive.
Hope this helps.
Muley is offline
